Home > Technical (L322) > Parking sensors, sometimes working, sometimes not. |
Had the same issue and I used my Faultmate to read the codes. Two sensors were defective and I replaced them (easy job at the back, bit of work at the front). If you can find someone that can read the faultcodes that is easiest.
6th Nov 2011 3:18pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi do you jetwash the car.. V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 3:22pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Yep. |
6th Nov 2011 3:27pm |
Thanks, will see if I can find someone who can read faults would make things easier. I tried the listening method, but couldn't hear anything :s |
6th Nov 2011 3:28pm |
jet washing can cause probs, do you find that they work and then they dont, i know on of my rears does not like being jet washed V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 3:32pm |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
one of mine on the front plays up when its wet. |
6th Nov 2011 3:34pm |
If the water is giving you issues, then take the connectors off, put some vaseline on and put them back. It won't help against the pressure of the jet wash but will keep rain water out and still allow electricity to go through (I also use it on the battery poles to keep corrosion off).
6th Nov 2011 8:21pm |
Guys, thanks for the help so far.
7th Nov 2011 1:04am |
On the rear bumper ones : push them out from behind the bumper, disconnect etc.
7th Nov 2011 6:19am |
Thanks again, will have a look over the weekend when I get a moment. |
7th Nov 2011 2:14pm |
