![]() | Home > General > Whats tomorow going to bring? 3 days of ownership |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
ooof! thats a biggie |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 ![]() ![]() ![]() |
If your having suspension issues on LPG then check your compressor location and angle of install... Just like a conventional workshop compressor they are designed to work one way up only and suck in moisture etc when mounted incorrectly...
Gav i am running a 4.4 with the zf auto so hopefully you are correct |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Hi Paul, as mentioned the ZF generally has less issues, but they do have a few quirks. There is a very good thread on this trannie - http://forum.landrovernet.com/showthread.p...4-teardown
Cheers Gav,make for a very interesting read and as you say this guy Bemble seems to be a whizz on ZF autos. Will give him a shout. Interesting to note that he very definately warns against dexron oil |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 ![]() ![]() |
Bemble a.k.a. RRPhil on this forum |
Even better |
Well,first time out since monday and it hasnt failed to disappoint |
It is maybe worth taking all the electric connectors off and spray them with WD-40 or CRC 2-26. Also disconnect the battery leads on the battery and clean the inside surface of the clamps of the leads and the battery poles. Then put a thin layer of vaseline on it to prevent any corrosion.
Thanks Ebajema,may give it a go. Fixed the cd changer the old fashioned way,gave it a whack and it started working again |
Clearly wasn't an electrical fault then |
![]() ![]() Paul ![]() 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
