Home > General > Whats tomorow going to bring? 3 days of ownership |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
ooof! thats a biggie ,have got a bit of a transmission judder on mine but i am hoping an oil and filter change may help this and its nothing terminal (fingers crossed)
23rd Oct 2011 1:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
If your having suspension issues on LPG then check your compressor location and angle of install... Just like a conventional workshop compressor they are designed to work one way up only and suck in moisture etc when mounted incorrectly...
25th Oct 2011 9:01am |
Gav i am running a 4.4 with the zf auto so hopefully you are correct . Good point Craig,my compressor is mounted out of its shell on a custom made bracket next to the gas tank in the spare wheel well. Started i up tonite for the first time since saturday and the compressor ran for at least a minute even though the air susp inactive light and message was on
25th Oct 2011 6:42pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Hi Paul, as mentioned the ZF generally has less issues, but they do have a few quirks. There is a very good thread on this trannie - http://forum.landrovernet.com/showthread.p...4-teardown
26th Oct 2011 8:26am |
Cheers Gav,make for a very interesting read and as you say this guy Bemble seems to be a whizz on ZF autos. Will give him a shout. Interesting to note that he very definately warns against dexron oil
26th Oct 2011 5:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Bemble a.k.a. RRPhil on this forum .
26th Oct 2011 6:04pm |
Even better Paul
26th Oct 2011 6:17pm |
Well,first time out since monday and it hasnt failed to disappoint ,todays new fault-cd changer,was working fine then came up no discs and mag wont eject
28th Oct 2011 6:50pm |
It is maybe worth taking all the electric connectors off and spray them with WD-40 or CRC 2-26. Also disconnect the battery leads on the battery and clean the inside surface of the clamps of the leads and the battery poles. Then put a thin layer of vaseline on it to prevent any corrosion.
28th Oct 2011 7:03pm |
Thanks Ebajema,may give it a go. Fixed the cd changer the old fashioned way,gave it a whack and it started working again ,nice to know that the Range rover responds well to cheap fixes
29th Oct 2011 12:47pm |
Clearly wasn't an electrical fault then
29th Oct 2011 1:39pm |
no,i guess not. Had a full day today with no faults . Maybe its learning? Paul Paul 2014 Range Rover vogue se 4.4sdv8 Loire Blue 1992 Range Rover Vogue LSE 4.2 Ardennes green |
29th Oct 2011 6:11pm |
