Home > Maintenance & Mods (L322) > Removing Land Rover Badge |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
talked about many times rad and there are many suggestions..no holes are left and the way i did it was to heat up the adhesive with a hairdryer and gently prise off the badge..you'll be left with the adhesive on the bodywork which you can rub of with your fingers.. ... - .- -.
30th Sep 2011 2:53pm |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 |
Thanks for the quick response.
30th Sep 2011 5:25pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Dental floss 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
2nd Oct 2011 6:43pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
nylon guitar string. V8 facelift Range Rover Autobiography 22" wheels.
2nd Oct 2011 9:04pm |
Just an update:
9th Oct 2011 1:35pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
G-string Present :2008 TDV8 HSE
9th Oct 2011 2:43pm |
9th Oct 2011 2:58pm |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 186 |
I'm replacing a knackered badge on mine - will the residual glue be sticky enough or do I need more glue - and if so, what type? 17 MY Corris Grey 4.4 VAB
16th Mar 2015 8:50pm |
Best use 3m double sided automotive tape the thinner the better and is what they use in the first place Present :2008 TDV8 HSE
16th Mar 2015 9:13pm |
Cheers. 17 MY Corris Grey 4.4 VAB
16th Mar 2015 9:39pm |
