Home > Maintenance & Mods (L322) > Removing Land Rover Badge
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Afternoon Chaps,
Just a quick question today -
I want to remove the rear tailgate oval 'Land Rover' badge, similar to that of the 2011 Range Rover.
Is there any easy way of doing this without damaging the paintwork? Also, has the tailgate got an indent for the badge, or is it all flush with no holes?
Thanks in advance.
Post #84765 30th Sep 2011 3:50pm
talked about many times rad and there are many suggestions..no holes are left and the way i did it was to heat up the adhesive with a hairdryer and gently prise off the badge..you'll be left with the adhesive on the bodywork which you can rub of with your fingers.. ... - .- -.
Post #84767 30th Sep 2011 3:53pm
EVOeng
Thanks for the quick response.
Will try this out over the weekend.
Post #84797 30th Sep 2011 6:25pm
Andy
Dental floss 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #85037 2nd Oct 2011 7:43pm
daveo
nylon guitar string. V8 facelift Range Rover Autobiography 22" wheels.
Post #85060 2nd Oct 2011 10:04pm
EVOeng
Just an update:
I used a hairdryer to loosen the glue and was left with the foreseeable ring of glue.
After getting as much of it off as possible with the hairdryer and scraper ‘tool’ – then proceeded to put some Super Resin Polish on it and get the remains off. Now, IMO the car looks fantastic!
Post #86224 9th Oct 2011 2:35pm
Googsy
G-string Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #86230 9th Oct 2011 3:43pm
Post #86231 9th Oct 2011 3:58pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
I'm replacing a knackered badge on mine - will the residual glue be sticky enough or do I need more glue - and if so, what type? 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #318331 16th Mar 2015 9:50pm
Googsy
Best use 3m double sided automotive tape the thinner the better and is what they use in the first place Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #318338 16th Mar 2015 10:13pm
Triarii
Cheers. Thumbs Up 17 MY Corris Grey 4.4 VAB
Post #318347 16th Mar 2015 10:39pm
