Home > General > pre heater question
Page 1 of 4 1234>
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
pre heater question
Ok so i have this pre heater function in my 05. It will be perfect when winter is coming. Like last winter when the temperature quite often were down to -25c/-27c.
My question is, will this function heat the engine compartment as well?
Those very cold starts are of course hard on the engine.
And also, are there any risks that by using this function the battery might drain?
Post #85130 3rd Oct 2011 9:35am
might this help... http://www.fullfatrr.com/wiki/FBH ... - .- -.
Post #85132 3rd Oct 2011 9:37am
starman
You got me again Very Happy Sorry, keep forgetting this wiki thing. Thanks.
Post #85135 3rd Oct 2011 9:40am
starman
Itīs probably my poor english, but i could not see information regarding heating the engine in wiki Confused
Post #85136 3rd Oct 2011 9:46am
hopefully plans are afoot to make the link more prominent...i forget about it too until i remind myself.. Very Happy ... - .- -.
Post #85137 3rd Oct 2011 9:46am
A1GSS
Does the TDV8 have the FBH as standard?
It's not clear in the wiki. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #85147 3rd Oct 2011 10:52am
found via search graham... http://www.fullfatrr.com/forum/topic1675.h...ing+heater ... - .- -.
Post #85149 3rd Oct 2011 11:02am
A1GSS
Doh. Thud
Soz. My bad (again). Thanks.
Seems like it works differently in the FFRR to the Discovery 3 - in my D3, the FBH warms the coolant resulting in more rapid engine warm-up (and potentially easier stating I guess), but is incapable of warming the cabin. Graham
____
Post #85163 3rd Oct 2011 12:01pm
simon1233
Graham, I had the same experience with my old RRS as the fuel burning heater used to just help heat up the engine coolant fluids faster. There were kits available which some of the D3 & RRS boys installed which meant you could call or text your car to start the heater and also the internal fans.
On a TDV8 Vogue you have the preheater as standard which is controlled either by a remote or a timer function in the main screen. Not used mine much yet so don't know if it makes a big difference to the engine getting up to temperature faster, but it certainly makes the cabin nice and warm when you get in on a cold morning.
I am looking forwards to the really bad weather...
Post #85177 3rd Oct 2011 3:25pm
A1GSS
yes, the TDV6 RRS and D3 are the same. I'm probably going to fit one of Pete Bell's kits to control the D3 remotely. Not got the TDV8 yet, but trying to get to grips with the various options...
Presumably a FFRR mod is available which circulates that warmed water through the block...? Graham
____
Post #85186 3rd Oct 2011 4:13pm
simon1233
Think that the pioneers used a kit by danhag(?) but Pete's kit looks very good. Apparently webasto make a kit that you can install to give remote pre/park heat. Seem to remember that when I was looking at these before I replaced the RRS that Pete's kit ticked all the boxes and was also more cost effective. Thumbs Up
Post #85189 3rd Oct 2011 5:13pm
A1GSS
Thread on disco3 covering the fitting of Pete's latest kit...
http://www.disco3.co.uk/forum/topic68260.html?highlight=%2Bfbh
and Pete's own thread:
http://www.disco3.co.uk/forum/topic67347.html Graham
____
Post #85190 3rd Oct 2011 5:22pm
stu
my understanding of this situation is thus...
the FFRR has like so many larger capacity diesel cars is fitted with a webasto auxilary heater. this kicks in automatically to aide warming the engine at a pre set temperature usually about 5 degs C. when it is cold enough you will see the vapours and smell the exhaust fumes so you will know it is working.
the FBH part of things is different!! the FFRR has the ability to heat or cool the cabin by the addition of the webasto tele start remote receiver or the timer unit on the main screen.
so if you have both parts, the engine will warm up quicker and the cabin will be heated already when you get in the car.
i hope that what i am saying is correct and maybe helps the understanding of things a bit.
please as usual correct me if i am wrong!!
it is like toast inside when you get in.... Very Happy Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #85327 4th Oct 2011 7:17pm
A1GSS
Ahah, best of both worlds.... Thumbs Up Graham
____
Post #85329 4th Oct 2011 7:33pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
except of course if you have a new FFRR
when it will be cold when you get in, and there will be a "low battery" warning
Post #85393 5th Oct 2011 8:31am
Page 1 of 4 1234>
