![]() | Home > General > New owner/member problem already!! |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi Sam,
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Welcome to the forum and congrats on your new FF |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Welcome and I know what it's like, haven't seen mine for the last three weeks.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Welcome and sorry for your woes already. Did you get any errors on the dash when you were stuck in 3rd? I'm no expert but sounds like its overheating. could be lots of reasons but would get EH to change the gearbox fluid and do a filter change. while there doing it get them to flush the trans cooler as that could be blocked causing the problem. Just remind then this issue has shown itself after a few in the first week so if its still not resolved after the warranty has expired you wont be paying a penny. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I would not let Evans Halshaw anywhere near a car of mine again. They are the worst dealer I know and haven't a clue how to toast a slice of bread let alone fix a FFRR.....Rant over
Sammyg1413 Member Since: 02 Oct 2011 Location: North west Posts: 16 ![]() ![]() |
Thanks for the quick reply guys!
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1022 ![]() |
All sorts of gremlins can cause it to go into limp mode, not necessarily related to the gearbox at all. It could be something as simple as a camshaft sensor!
When you say it wouldn't leave third gear - did it pull away in third too? Or was it just sticking to the lower gears?
I didn't have any lights on when restarting I'd just come off an hour or so motorway driving so don't think I flattened the bat. I was driving alot in traffic thru Leeds. It seemed to hold onto the gears a bit too much thinking back. Over 4-5k revs before changing.
If it is sticking in the low gears up to 4-5k then it is in cooldown mode - as doccumented in the workshop manual. Get your gearbox oil changed (every 50K, has it ever been changed?) Get your engine coolant changed. There is an oil-water heat transfer unit that can get clogged. When was your coolant last changed? ![]() |
I've only just bought the car so don't know any history. I've not yet received the history it's on its way (I only purchased car on condition I for the s/h if not they have agreed to return the car). It was a part ex at one of their stratatone dealerships so the owner has yet to hand in s/h but has been done upto 50k at LR then last service at specialist.
You're not familiar with Land Rover dealers then!? Several members have has the full service done yet they've not even replaced the air filter! Just because the books been stamped doesnt mean the stealer has done the work - it's a shame, but its reality. ![]() |
So it's every aspect of LR which is bad by the sounds of it! Just wonder where Land Rover would be if BMW didn't rescue them with the L322!
You can get a pipet type tester from halfrauds to test it. I would get it changed anyway. Where abouts are you? Someone might be local who can help. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
