![]() | Home > Technical (L322) > Fluid on my drive this morning |
The picture shows the oil filter on the left and power steering fluid on the right, do you know if the leak is from any of them? |
Scorchio Member Since: 28 Apr 2010 Location: Staffordshire Posts: 24 ![]() ![]() ![]() |
It's the oil filter then, there is fluid all around the top of it, as if it isn't screwed on right (! ?) - is this possible ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
looks like its worked its way loose, try tightening it .......... ... - .- -.
Be careful not to over tighten it |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Their is a large o ring in the top of the oil filter housing, check it's seated correctly/not perished.
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
is it 100% oil as i had the same and it was my header tank that had split and kept dripping |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
It's good. That means no rust !
Right - opened the filter housing, rubber ring looks ok - in my limited experience !
It needs to be more than finger tight, best fit a new rubber ring too |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
buy an oil filter kit , Replace the oil filter , Replace the O rings
Thanks Speedy Mark ... I'm near Uttoexeter, however ...
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
DLS!!!, got a warranty claim over 1 year with them on lower from arms, STILL no refund!!!, I won't recommend regardless how helpfully they have been, my hard spent cash, and still not bothered to refund..........
Just found this..
