Home > Technical (L322) > Fluid on my drive this morning
Scorchio
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Please help guys since I am clueless !
Stuff all over the drive this morning coming from here -
Is it a coincidence Halfords did an air-con re-gas yesterday ?
Thanks in advance 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #84564 29th Sep 2011 11:59am
The picture shows the oil filter on the left and power steering fluid on the right, do you know if the leak is from any of them?
Post #84565 29th Sep 2011 12:02pm
Scorchio
It's the oil filter then, there is fluid all around the top of it, as if it isn't screwed on right (! ?) - is this possible ?
Then it's pooling lower down in the enigine compartment and ultimately all over my block paving .... grrrrr
Sorry for being so dumb - never touched a spanner in my life ... 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #84566 29th Sep 2011 12:08pm
looks like its worked its way loose, try tightening it .......... ... - .- -.
Post #84567 29th Sep 2011 12:13pm
Be careful not to over tighten it
Post #84573 29th Sep 2011 12:49pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Their is a large o ring in the top of the oil filter housing, check it's seated correctly/not perished.
Also worth checking breathers etc, as blocked ones may over preasurizing the system.
Post #84580 29th Sep 2011 1:31pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
is it 100% oil as i had the same and it was my header tank that had split and kept dripping
Post #84594 29th Sep 2011 3:19pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
It's good. That means no rust !
It's oil from the oil filter housing. Did you changed the filterelement in the past? Open the oil filter housing, check the large black rubber ring is correct and undamaged, a drop oil around the rubber ring and then close the oil filter housing strong by hand - without a spanner! That will be enough.
Check engine oil , if necessary fill up correctly.
Spray a can brake cleaner into the cold engine compartment, that will clean the desaster...or wait until the next rain.... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #84601 29th Sep 2011 3:56pm
Scorchio
Right - opened the filter housing, rubber ring looks ok - in my limited experience !
Closed it tightly by hand. Started the engine and immediately oil is oozing out all around the top.
Richcl mentioned "breathers" ... is he right - how do i diagnose that problem ! ?
Thanks 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #84605 29th Sep 2011 4:09pm
It needs to be more than finger tight, best fit a new rubber ring too
Post #84608 29th Sep 2011 4:11pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
buy an oil filter kit , Replace the oil filter , Replace the O rings
Buy a cheap torque wrench and a 36mm socket i believe and torque it up to what is stamped on the plastic top
as NO amount of hand tightning is going to be tight enough then you will know if you really do have a problem im in birmingham outskirts if you was closer i would have done it for u as i have all of the tools (wher bouts are you) onto no6 Range Rover
Everyone needs a hobby
Post #84719 30th Sep 2011 8:42am
Scorchio
Thanks Speedy Mark ... I'm near Uttoexeter, however ...
Just checked and when it was last MOT'd in June, the garage (DLS in Matlock) did an oil filter change ... so I'm just about to get on the phone to them.
Thanks for the offer though Very Happy 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #84724 30th Sep 2011 9:01am
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
DLS Caution advised!!!!!
DLS!!!, got a warranty claim over 1 year with them on lower from arms, STILL no refund!!!, I won't recommend regardless how helpfully they have been, my hard spent cash, and still not bothered to refund..........
Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #84907 1st Oct 2011 5:13pm
Richcl
Just found this..
http://www.rangerovers.net/repairdetails/e...ilter.html
Post #85140 3rd Oct 2011 10:08am
