![]() | Home > Maintenance & Mods (L322) > Mass Air Sensor |
The MAF/IAT sensor on the TD6 (pre 2006) is fitted with two torx bolts (female) according to the workshop manual that I downloaded. It is located on the (UK) driver side of the engine near the front (radiator). I would be surprised that on the MY 2006 that has changed. Try to find the workshop manual online and download it, I would suggest.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Sorry only kidding! As suggested look at the other fuel pump, I had a 530d, same engine basically, and had to change both fuel pumps, then it was good as new! ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Why not try removing the whole MAF assembly, just unclip the hose connectors at either end, work the MAF off the hoses, disconnect the plug, then you have access to the sensor. If you can get the sensor out, you can soak and agitate it in isopropyl alcohol (rubbing alcohol?) then dry it out and refit.
scrosbie Member Since: 27 Sep 2011 Location: North Yorkshire Posts: 2 ![]() ![]() ![]() |
I have not been able to find a download for the workshop manual for this generation, 2006 to 2009. Can anybody send me a link. Thanks |
Does this help?
