Home > Maintenance & Mods (L322) > LED Bulbs
Page 2 of 5 <12345>
dantheman
Cheers Ken - will get on the case!
Post #8270 5th Nov 2009 1:32am
I just bought a pair and they are a good colour match for the HID main beams Thumbs Up battery went flat fitting them Banging Head think I now need a new battery Big Cry 2008 MY Supercharged
Post #8271 5th Nov 2009 11:16am
Was driving back from Heathrow in the rain and gloom the other day and discussed this with Mrs RRUK.
Basically, I think that sidelights are a total waste of time, they are NEVER bright enough, they should ditch them and just make it dipped beam instead.
There were so many feckin idiots driving in near invisibility with sidelights on, the power of a candle at best.
I wanted to shout out the window "SWITCH YOUR BLOODY HEADLIGHTS ON YOU TW@T!"
If they crash and die, it's their problem but I don't want to crash into them cos I can't see them coming. So many drivers' attitudes are "well I can see everyone else so it's OK". They are burgling our air. Discovery 4 HSE
Post #8278 5th Nov 2009 5:19pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
so whos baught the ones that ken linked and what are they like pref with pics could be tempted as cheap enough Thumbs Up Thumbs Up just jumping on the band wagen onto no6 Range Rover
Everyone needs a hobby
Post #8362 10th Nov 2009 6:29pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
What size are the sidelight bulbs? I'll have a look for a few prices. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #8368 11th Nov 2009 10:10am
speedymarktd6
i think they are the 501 / 5watt type Thumbs Up onto no6 Range Rover
Post #8373 11th Nov 2009 7:30pm
Yep 501 5w, just a bit busy right now to take pictures but they are a fair colour mach. 2008 MY Supercharged
Post #8374 11th Nov 2009 8:33pm
Macdaddy
These arrived today :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT
Going to fit them and i'll try to get pics later of the before/after.
Also ordered 3mm LED's to replace the internal door handle ones for a soft white. (not keen on the green)
10mm LED's are next to convert the wing mirror path lights from aht horrid yellow light to the nice white light seen on later models. TDV8 HST Sport **Current**
Post #8406 13th Nov 2009 11:26am
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
The concern I have with these is as follows...
The incandescent bulbs work within a reflector housing; LED bulbs are directional (ie there is no light emitted from the back of the bulb) so you will have less light as the reflectors are not doing their job.
Interesting to see if you prefer form over function Razz
Post #8418 14th Nov 2009 12:40am
dan_uk_1984
That's because 75% of the light from incandescent bulbs does not go forwards, most is emitted around the side.
With an LED bulb being directionally efficient, this isn't a problem.
Post #8421 14th Nov 2009 11:31am
jayzee
Absolutely correct, and the reflector "magnifies" this with it's shape - so directional light from LED = less light Whistle
Look at the low voltage Halogens you use in your house. Why bother with the reflector? Easy, the bulb on it's own isn't enough to produce the required brightness.
Post #8427 15th Nov 2009 12:04am
nbunney
Mac
How did you get on?
Did you get any error codes up?
Post #10543 5th Jan 2010 10:59pm
Macdaddy
Unfortunatly they threw the "check sidelight" code up.
I ditched them and bought ones with resistors which cause no isses. TDV8 HST Sport **Current**
Post #10889 10th Jan 2010 5:15pm
Steve R
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
I just swapped my side light bulbs for LED versions today and thought the bulb spec may be of interest to others.
I went for these bulbs:
http://www.ultraleds.co.uk/501194t10-anti-...-2177.html
I'm pretty happy with the results, they don't throw up any bulb warnings, they are bright (certainly compared with other LED bulbs I've used in the past), and the colour is a very good match for the xenons without being too blue like some are.
Only slight faff is that you have to file a tiny amount off the corners of the PCB to allow the bulb to pass through the hole in the back of the light unit. 2 seconds with a file had it sorted though.
Here's the before and after photos...
BEFORE:
AFTER:
Hope this is of use and takes away some of the gamble re bulb warnings etc.
Cheers,
Steve. 2013 Range Rover Evoque Coupe
2013 Defender 110 XS Utility Wagon
1975 3.9V8 Lightweight
Post #16005 31st Mar 2010 10:38pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
dan ebay sell one with the canbus resistor thing to stop that fault i just got some but they sent me blue that did not look good even tho my 16 year old thought i was "sick" i have returned them for a replacement 02 Range Rover HSE Zambezie silver 4.4
Post #16008 31st Mar 2010 10:49pm
Page 2 of 5 <12345>
