![]() | Home > Maintenance & Mods (L322) > LED Bulbs |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
Nick, I've just bought a couple for no plate, will report back. |
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
I really fancy some rear LED number plate lamps for my 07....did anyone source anything that worked?
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
hi plenty on flea bay. just make sure they are error free. |
quabba Member Since: 29 Aug 2014 Location: North Lanarkshire Posts: 39 ![]() ![]() ![]() |
Is it easy to fit the sidelight led's. I've heard that you need to take the headlight unit out |
oh no....don't say that........ |
Just fitted mine as they arrived today. I looked at the manual and thought sod this, no way I'm getting my hand in there without taking the unit out. So out they came. It was a 2 minute job and they look brilliant........
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Did the LED side lights on mine too last night.
Interesting.....what bulb type was it you used for the interior ones you changed? I've thought about buying the kit for the interior lights...... |
I used the same ones as for the side lights
That's lucky then.....I've go two left.....they'll be going in there tomorrow!!! |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Would I be right in guessing that the indicator and reversing light bulbs are the same 501 LED fitment as the sidelights? Might as well do the lot at once if I'm buying sidelights... NW060
The same bulbs don't physically fit in the reversing light and no alternative LED seams to be available unless you are able to fabricate something with small LED panels - various threads on the subject else where.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
@mat,
Y. O. L. O. . |
thanks stan |
