Home > Maintenance & Mods (L322) > roof linig and rubber coating
daveo
hi all,
have a few grubby marks on the roof linig, whats the best way of cleaning them and what to use, its a cloth linig
what can be done about the rubber coating they put over the switch surrounds,cup holder, it can start to peel off if cought .
thanks daveo
Post #8208 2nd Nov 2009 10:22pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
not sure on the headlinning could try a vehicle valeter , as for switches / rubber replacement of parts or peel he rest off Rolling with laughter Rolling with laughter onto no6 Range Rover
Everyone needs a hobby
Post #8222 3rd Nov 2009 6:06pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
foam cleaner will work with a interior sponge careful as the whole HL will be dirty
Post #8228 3rd Nov 2009 7:47pm
daveo
is it possible to clean the whole head linig
daveo
Post #8232 3rd Nov 2009 9:03pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Try it on one patch and it'll look awful - do the lot.
I use a product called Groom from Halfords. Ambersil make it IIRC and it has an orange cap.
Spray the foam over the entire headlining and wipe down with a damp (not wet) cloth. Keep rinsing the cloth in clean water. Do not rub hard, or rub the same area too hard. The foam will get to work to remove the dirt.
Do that a couple of times, and the headlining will be as good as new.
You will be surprised how much muck is on there!
Post #8236 3rd Nov 2009 11:36pm
daveo
hi thanks, i will give it a go....
daveo
Post #8256 4th Nov 2009 7:24pm
