Home > Technical (L322) > 4.4 v8 engine management light |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hows your breather pips at the back of the engine, are they good and firm or have they gone all soft..how does it run, any missing V8 facelift Range Rover Autobiography 22" wheels.
12th Sep 2011 10:01pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 208 |
hi no miss fire , the two lager breather pipes have been renewed and the two small ones also the pcv valve renewed 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
12th Sep 2011 10:06pm |
Is it LPG? |
12th Sep 2011 10:26pm |
no lpg when the light comes on there is no power loss 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
13th Sep 2011 5:56am |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Did the light come on shortly after refuelling and if so did you put crappy petrol in it?
14th Sep 2011 2:49pm |
yes you may have a point there , i will give it a go i also have some forte petrol treatment to add as well 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
14th Sep 2011 5:38pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Andrew could well be right. I had an EML come on in my 728i after filling it with crappy fuel from France. Could just be you got a bad batch from a supermarket or something? Range Rover-less at the moment - Pining! |
14th Sep 2011 5:55pm |
going on a 70 mile run saturday morning so fingers crossed , we will see what happens and i will post the results 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
15th Sep 2011 6:03am |
How much old stuff was left in the tank and how much did you put in today? |
15th Sep 2011 7:10am |
i am low on the tesco fuel so i will flood the tank with super plus and see what happens 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
16th Sep 2011 6:16am |
update well put £70 of super unleaded in and guess what after 15 miles on comes the light again thinking one or more of the o2 sensors must be on the way out . 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
18th Sep 2011 8:29am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Could it be you MAF meter? From what i can remember there relitivly cheap and an easy to fit. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
18th Sep 2011 9:09am |
further update on this fault i have recently fitted 2010 rear led lights and the fault has been apparent since they were fitted so i refitted the standard lights and the fault has gone so it must be something that the car doesnt like about these led lights the led lights were fitted with the powerfull uk modification to fix the fog light problem which it did- but still had the check fog light message on dash the fast flash indicator fault was cured by wireing in a side repeater in the loom . now do i buy 1 of these dedicated modules sold on fleabay for £120 and hope it fixes all faults or just put my origanal lights back in 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
24th Sep 2011 8:55am |
How old is your battery? Have you had it tested recently? Are you sure that the lights are the cause of your problem and not a failing battery throwing erroneous fault codes?
24th Sep 2011 9:05am |
