Home > Technical (L322) > 4.4 v8 engine management light
klf400
hi everyone this is my first post so dont hit me to hard lols
i have a 2004 l322 4.4 v8 last few days my engine management light has came on a few times
i have cleared the fault with my rsw allcomms kit but after8-10 miles it comes back on the faults are as follows
O2 sensor heater circuit bank 1 upstream sensor fault. Last occurrence - maximum signal
Lambda control adaption exceeds lower limit bank 1. Last occurrence - maximum signal
Lambda control adaption exceeds lower limit bank 2. Last occurrence - maximum signal
any ideas of the way forward Confused 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #80760 12th Sep 2011 9:29pm
daveo
hows your breather pips at the back of the engine, are they good and firm or have they gone all soft..how does it run, any missing V8 facelift Range Rover Autobiography 22" wheels.
Post #80764 12th Sep 2011 10:01pm
klf400
hi no miss fire , the two lager breather pipes have been renewed and the two small ones also the pcv valve renewed 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #80766 12th Sep 2011 10:06pm
Is it LPG?
Post #80767 12th Sep 2011 10:26pm
klf400
Gazellio wrote:
Is it LPG?
no lpg
when the light comes on there is no power loss 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #80785 13th Sep 2011 5:56am
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Did the light come on shortly after refuelling and if so did you put crappy petrol in it?
If I fill up with ssome upermarket rubbish or low octane French stuff the engine light sometimes comes on and shows a Lambda fault. Refilling with decent stuff clears the light.
I've never had a problem with Texaco or Shellfuel. The Tesco 99 stuff seems ok too but these days I try and stick to Texaco only.
I know it's more expensive but only by about £5 on a full tank and it looks after your engine better and you should see an improved mpg figure.
Try that and see if it clears the light.
Post #81263 14th Sep 2011 2:49pm
klf400
yes you may have a point there , i will give it a go i also have some forte petrol treatment to add as well 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #81300 14th Sep 2011 5:38pm
bozmandb9
Andrew could well be right. I had an EML come on in my 728i after filling it with crappy fuel from France. Could just be you got a bad batch from a supermarket or something? Range Rover-less at the moment - Pining!
Post #81307 14th Sep 2011 5:55pm
klf400
going on a 70 mile run saturday morning so fingers crossed , we will see what happens and i will post the results 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #81378 15th Sep 2011 6:03am
AndrewT
How much old stuff was left in the tank and how much did you put in today?
Post #81381 15th Sep 2011 7:10am
klf400
i am low on the tesco fuel so i will flood the tank with super plus and see what happens 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #81639 16th Sep 2011 6:16am
klf400
Re: 4.4 v8 engine management light
update
well put £70 of super unleaded in and guess what after 15 miles on comes the light again
thinking one or more of the o2 sensors must be on the way out . Confused 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #82147 18th Sep 2011 8:29am
Could it be you MAF meter? From what i can remember there relitivly cheap and an easy to fit. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #82153 18th Sep 2011 9:09am
klf400
update
further update on this fault i have recently fitted 2010 rear led lights and the fault has been apparent since they were fitted
so i refitted the standard lights and the fault has gone so it must be something that the car doesnt like about these led lights
the led lights were fitted with the powerfull uk modification to fix the fog light problem which it did- but still had the check fog light message on dash the fast flash indicator fault was cured by wireing in a side repeater in the loom .
now do i buy 1 of these dedicated modules sold on fleabay for £120 and hope it fixes all faults or just put my origanal lights back in 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #83606 24th Sep 2011 8:55am
bozmandb9
How old is your battery? Have you had it tested recently? Are you sure that the lights are the cause of your problem and not a failing battery throwing erroneous fault codes?
I don't see why the rear lights should give you faults in engine / emissions ecu's. However many incorrect faults are caused by a battery beginning to go!
I've been getting a couple on my car, catalyst below efficiency/ reduced engine performance/ gearbox fault, and yesterday the battery failed to start the car after just a few minutes leaving the key in ignition, so I'm getting it replaced to today, and I bet if fixes the fault codes. Thumbs Up Range Rover-less at the moment - Pining!
Post #83607 24th Sep 2011 9:05am
