![]() | Home > Technical (L322) > Towing electrics not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
i would guess the trailer fuses but you get that message so that gets confusing..
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
do you have the towing module fitted?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
When I did mine it was just plug ‘n play – here’s the relay connections :
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
Isn't the white Siemens box the towing module? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
did u connect the earth cable thats by the rubber grommet that enters the car it attaches to the bumper bolts i think |
No, as I thought that was just a failsafe and there were earth in the main connectors. I'll attach them and try again. |
just a thaught as it can be missed but i hope it solves your problems |
I've checked all the fuses, unplugged and replugged everything but now it's getting ridiculous.
the trailer socket might have a loose/dodgy connection? and is giving the wrong signals to the range.....can you try another socket maybe.. |
Can't try another socket but I'll pull this one apart and see if the connections are all good. |
There's no corrosion in the socket causing shorts circuits from terminal to terminal by any chance? |
I checked for shorts across all the terminals and there were none. Continuity up all the cables was fine so I plugged it all back together and now it works fine.
something made the car think that..its process of elimination i'm afraid so next step maybe the relay.. |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Interesting they obviously changed the loom at some point; my loom, which I bought second hand, doesn't have a relay at all. |
