Home > Technical (L322) > Towing electrics not working
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
I recently fitted a towbar and genuine LR twin socket electrics but nothing works and I am completely stumped.
The electrics loom ends in 3 bits that go inside the car - a white connector, a black connector and a small relay type thing. I plugged the white Siemens control module into the black connector and the white one I connected to a white plug which was the only thing that it could connect to under the right side panel in the boot. The relay is just hanging around in there as it didn't look as though I should connect it to anything.
Without a trailer attached there are no problems with the electrics and no messages showing so I assume that it is correctly wired.
When I attach a trailer none of the trailer lights will work, the suspension still moves up and down and the rear parking sensors still work. I get a message up saying "Check trailer electrics" which disappears after a few seconds so it is registering something.
Does anyone know what might be wrong? Does it need programming by a dealer? I thought it was plug and play.
Post #80796 13th Sep 2011 9:01am
i would guess the trailer fuses but you get that message so that gets confusing..
Post #80800 13th Sep 2011 9:12am
duckworthparts
Site Sponsor
do you have the towing module fitted?
a dealer will need to hook it upto testbook ideally. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #80801 13th Sep 2011 9:13am
RRPhil
When I did mine it was just plug ‘n play – here’s the relay connections :
Phil
Post #80802 13th Sep 2011 9:18am
AndrewT
Isn't the white Siemens box the towing module?
Post #80805 13th Sep 2011 9:36am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
did u connect the earth cable thats by the rubber grommet that enters the car it attaches to the bumper bolts i think Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #80807 13th Sep 2011 9:39am
AndrewT
No, as I thought that was just a failsafe and there were earth in the main connectors. I'll attach them and try again.
Post #80830 13th Sep 2011 10:37am
speedymarktd6
just a thaught as it can be missed but i hope it solves your problems Thumbs Up onto no6 Range Rover
Post #80839 13th Sep 2011 11:21am
AndrewT
I've checked all the fuses, unplugged and replugged everything but now it's getting ridiculous.
The display is telling me that I'm in trailer mode, suspension is locked and rear PDC is off but...... there is no trailer plugged in!!!!
Haven't had a chance to plug in a known working trailer board yet so I don't know if the main problem is fixed.
Anyone got any ideas? Question
Post #81260 14th Sep 2011 3:41pm
the trailer socket might have a loose/dodgy connection? and is giving the wrong signals to the range.....can you try another socket maybe..
Post #81261 14th Sep 2011 3:45pm
AndrewT
Can't try another socket but I'll pull this one apart and see if the connections are all good.
Post #81265 14th Sep 2011 3:51pm
There's no corrosion in the socket causing shorts circuits from terminal to terminal by any chance?
Post #81266 14th Sep 2011 3:55pm
AndrewT
I checked for shorts across all the terminals and there were none. Continuity up all the cables was fine so I plugged it all back together and now it works fine.
Don't know what was going on there but at least the problem has gone away.
What does that relay do? If that was sticking open or closed would it trick the car into thinking that something was connected?
Post #81284 14th Sep 2011 5:47pm
something made the car think that..its process of elimination i'm afraid so next step maybe the relay..
Post #81285 14th Sep 2011 5:53pm
ric355
Interesting they obviously changed the loom at some point; my loom, which I bought second hand, doesn't have a relay at all.
Post #81294 14th Sep 2011 6:26pm
