Home > In Car Electronics (L322) > Tow Bar Electrics |
Here you go. Main connector circled in green and the supplementary relay is arrowed in green.
11th Sep 2011 11:33am |
You need to buy the Genuine LR electrics for the 13pin euro plug. This a short length of loom that coverts everything for you. Then you can rest assured that everything will work as LR intended...
11th Sep 2011 12:43pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
thanks for the replies guys, especially Dom for the fab picture!!
11th Sep 2011 1:20pm |
just been out to car, i seem to have the main white plug, but it isn't being used just hanging free. don't seem to have smaller black plug though. is that part of the L/R loom that i will be adding in?
11th Sep 2011 1:35pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Oh dear. Sounds like your local fitter has done a job. |
11th Sep 2011 4:01pm |
yes looks a bit that way...
11th Sep 2011 5:59pm |
OK, the black module you refer to is nothing to do with towing electrics.
11th Sep 2011 6:09pm |
thanks for that Dom. looks like i have everything i should have then if the other plug is part of the kit loom.
11th Sep 2011 8:26pm |
You will also need the proper towing module which is another £55 ish quid but is the black box in the picture above about 1-2" to the left of the white plug. It's a simple job to fit but take out the spare wheel and get some old carpet to lay on while you try an feed the fecka thru the tiny hole in the body and seal it right!
11th Sep 2011 9:42pm |
Tried that with SWMBO and when I awoke in hospital the doctor said I was lucky to be alive |
11th Sep 2011 9:50pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
11th Sep 2011 10:26pm |
i bought a genuine set of twin electrics complete with towing module last night from ebay, sorry if i beat you for these!!...
15th Sep 2011 4:43pm |
You should be fine fitting the 13 pin plug yourself. The FFRR does not have a switched socket like some others (Mercs) so a standard socket can be wired on. The genuine ones are filled with potting resin to keep the moisture out though so you might want to do this yourself. Oh, and buy a high quality socket with stainless contacts, not the cheapie brass thing.
15th Sep 2011 5:58pm |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Provided there are no redundant wires from the loom you shouldn't have any problems. |
15th Sep 2011 6:02pm |
