![]() | Home > General > Airbag light won't go off after flat battery! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
could be the battery, now its up to charge, dis-connect it for a while and see if that resets the light.. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Tried disconnecting the earth already. Is there a secret trick reset or will disconnecting earth suffice? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I'm sure because it's a safety related item, it has to be reset by dealer (or garage that has equipment) |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
I used to have an old Disco td300. One I disturbed the fuse that controlled the airbags. The light was permanently on afterwards, I was told that it had to be reset by LR. I didn't bother as it wasn't an MOT item then.
it wont reset it self, it will have to be reset. V8 facelift Range Rover Autobiography 22" wheels.
i have a all comms unit, i think that will do it... i in london if any good.. V8 facelift Range Rover Autobiography 22" wheels.
Thanks all. Daveo= great offer and if closer would take you up on it. The garage that read it had a universal diagnostic equipment and this wouldn't reset it. He tried and fault came back.
if you have had it reset and it has came back on then you must have a faulty bag...did his system not tell you what air bag was faulty or module, V8 facelift Range Rover Autobiography 22" wheels.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My airbag warning lamp required the intervention of LR engineering to extinguish it, fingers crossed yours will be easier to sort out.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
my airbag lights still on a normal diagnostic obd unit wont turn it off it needs to be faultmate , rover all coms or main dealer .....there may be other systems that do it but these are systems im sure will turn it off
Diagnostic system just said low power but nothing else. Think its a case of having it reset at a specialists. |
Had it looked at by another Land rover indy today with an 'Autologic system'. Does anyone know if this should reset it? It kept coming up with 'Battery Diconect unit' and when cleared just came back.
found this on rave, it might lead you in the right direction...
item 6 nick...
