Home > General > Airbag light won't go off after flat battery!
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Not used car for a while just before needing to MOT. When went to start had flat battery so jump started from jump pack and now my airbag light won't go out. Been on a good run so shouldn't be low voltage. Had the fault code read and says power supply issue. Comes on again when reset.
Any ideas. Is the flat battery coincidence to another fault?
Is there any fuses for airbags?
Post #80203 10th Sep 2011 8:08am
could be the battery, now its up to charge, dis-connect it for a while and see if that resets the light..
Post #80215 10th Sep 2011 9:00am
Nickj
Tried disconnecting the earth already. Is there a secret trick reset or will disconnecting earth suffice?
Post #80229 10th Sep 2011 11:44am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'm sure because it's a safety related item, it has to be reset by dealer (or garage that has equipment)
Post #80233 10th Sep 2011 11:51am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I used to have an old Disco td300. One I disturbed the fuse that controlled the airbags. The light was permanently on afterwards, I was told that it had to be reset by LR. I didn't bother as it wasn't an MOT item then.
Now it is included in the MOT I believe. Have you checked the sensors under the seats? My light very occasionally comes on, but only when I have a passenger. If I get them to juggle about the light goes off. Maybe you have a dodgy sensor. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #80298 10th Sep 2011 5:58pm
daveo
it wont reset it self, it will have to be reset. V8 facelift Range Rover Autobiography 22" wheels.
Post #80306 10th Sep 2011 6:27pm
daveo
i have a all comms unit, i think that will do it... i in london if any good.. V8 facelift Range Rover Autobiography 22" wheels.
Post #80308 10th Sep 2011 6:30pm
Nickj
Thanks all. Daveo= great offer and if closer would take you up on it. The garage that read it had a universal diagnostic equipment and this wouldn't reset it. He tried and fault came back.
Pretty sure no wires disturbed and must be related to flat battery.
Guess its a trip to LR.
Didn't fail the MOT though (on this at least!)
Post #80329 10th Sep 2011 8:38pm
daveo
if you have had it reset and it has came back on then you must have a faulty bag...did his system not tell you what air bag was faulty or module, V8 facelift Range Rover Autobiography 22" wheels.
Post #80340 10th Sep 2011 9:51pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My airbag warning lamp required the intervention of LR engineering to extinguish it, fingers crossed yours will be easier to sort out.
http://www.fullfatrr.com/forum/topic5533.h...ning+light
Gone - Range Rover Supercharged 2006
Post #80344 10th Sep 2011 10:11pm
pretlove
my airbag lights still on a normal diagnostic obd unit wont turn it off it needs to be faultmate , rover all coms or main dealer .....there may be other systems that do it but these are systems im sure will turn it off
@dave where in london are you as i could do with getting mine turned off "RANGEISM WILL NOT BE TOLERATED"
Post #80348 11th Sep 2011 12:55am
Nickj
Diagnostic system just said low power but nothing else. Think its a case of having it reset at a specialists.
Post #80524 12th Sep 2011 9:22am
Nickj
Had it looked at by another Land rover indy today with an 'Autologic system'. Does anyone know if this should reset it? It kept coming up with 'Battery Diconect unit' and when cleared just came back.
He's making a few calls to his tech people, but i wonder if this system is not faultmate , rover all coms or main dealer as previously suggested will it not turn it off??
He's adamant it should reset it which confuses me?!
Anyone heard of 'battery disconect unit'?
Post #83113 22nd Sep 2011 10:35am
found this on rave, it might lead you in the right direction...
Post #83117 22nd Sep 2011 10:43am
item 6 nick...
Post #83119 22nd Sep 2011 10:49am
