![]() | Home > Technical (L322) > Vibration at around 40mph.......Diff problem? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Please note – The following applies to the ZF 5HP24 transmission fitted in the ’02-’05MY 4.4 BMW V8 L322. The GM 5L40-E transmission fitted in ’02-‘06MY 3.0 TD6 and the ZF 6HP26 transmission fitted post-‘06 (to both petrol & diesel models) will have different characteristics.
The 56mph ‘rule’ still applies even with the cruise control activated (see measured result below). If the cruise control is activated below 56mph the LUC will be in continuous slip mode (where its application pressure is modulated according to engine torque to maintain a continuous slip speed of around 3%). Above 56mph the LUC will be locked solid.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Thanks for your input Phil.
Hi Paul,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35514 ![]() ![]() |
phil are you the famous 'phil' from the rangeroversnet site that rebuilds gearboxs .. |
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 ![]() ![]() |
I think he is Scarey |
Ermm, yes – but I’m pretty sure that I’m not famous |
you defo know your stuff mate..welcome ... |
Thanks for taking the time to explain Phil. |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Finally got out for a long drive around Anglesea and much of north wales the other day and the vibration is still very much there.. after I though I'd fixed it with the tire pressures |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Hi Jon, Sorry I've been away and have only just caught up on forum posts ![]() The official diff recall was carried out having previously had 2 earlier attempts at solving "diff issues" so it definately wont be that! When I first had the car it appeared to have the symptoms you are referring too and it turned out to be "cupped" Goodyear tyres ![]() ![]() Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
"cupped tyres" are often caused by worn shocks. If that is the cause of cupping, fitting new tyres will eventually result in the new tyres getting cupped as well, unless the cause of the original problem is rectified. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
Just an update following fluid and filter change last Friday
In this instance I dont believe that to be the case as the cupping was evident on the Goodyears at 30k miles, I then changed to the Michelins and did 40k on that set without any "cupping" - If there was an underlying problem that caused the cupping it would have show itself over that 40k miles or the subsequent 35k. Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
