Home > Technical (L322) > Vibration at around 40mph.......Diff problem?
Page 2 of 7 <1234567>
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Well, they flushed it, new filter and fluid.
No difference, same issue.
The mechanic said the old fluid looked ok and seems to think it's not gearbox related.
His recommended getting the diff recall work done to eliminate that.
Guy Salmon are still saying the recall work can't be done till end of September due to back order on parts.
Due to the vibration they have raised my job to 'critical'. This hopefully means it will get done sooner.
The Guy Salmon service guy did say the diff issue could cause vibration
Fingers crossed, if not it's back to Tooting for another go.
Post #75925 12th Aug 2011 5:44pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
I'm eager to see what is causing it..
Have the same problem, feels like driving over a cattle grid when gently accelerating at low revs above ~50mph
it's fine when not increasing speed or at mid/high revs.. keep us updated Paul! Thumbs Up
Post #75934 12th Aug 2011 6:48pm
JonP
2003 Range Rover Vogue 4.4 V8 Epsom Green
Same here Thumbs Up
Post #75938 12th Aug 2011 7:03pm
PaulB
Have you both had the front diff recall done?
Post #75939 12th Aug 2011 7:13pm
havnt you paul?.....just ring any lr dealer and ask ,they will tell you.
Post #75942 12th Aug 2011 7:42pm
JonP
I have only had the car a short time Paul I bought it from a fellow forum member Ajay and im pretty sure he said it had been done
Post #75944 12th Aug 2011 7:44pm
PaulB
im waiting for the parts to become available Sad
Post #75961 12th Aug 2011 9:27pm
PaulB
Just give a LR main dealer your VIN number and they can confirm it mate.
Where in Surrey are you?
Post #75962 12th Aug 2011 9:28pm
JonP
I live in Ash but I work in Merton Thumbs Up
Post #75963 12th Aug 2011 9:32pm
mrd1990
Any news Paul?
I've had the diff recall done in 2008 so it's not related to that Confused
Post #76495 16th Aug 2011 4:55pm
JonP
Any more news on this ?
Post #76882 20th Aug 2011 9:24pm
mrd1990
I think I solved it yesterday
Check your tire pressures!!
They should be exactly 2.5 for back and 2.4 at the front.. all my tires were around ~2.2 but the rear right was slightly lower.. pumped all back to correct pressures and on the short test drive after, didn't noticed any vibration at all.
It was only a short drive and I didn't get above 50 (bloody caravaners!) and the car never really had a chance to warm up so I can't be 100% sure, but it seemed promising.
Post #76889 20th Aug 2011 10:17pm
PaulB
I'm away ATM so no update.
The guy I bought the car from has asked me to get the diff recall done before he will undertake any further investigation.
Guy Salmon are still saying it's weeks away, but when I get back I will be asking again Big Cry
Post #77088 22nd Aug 2011 3:27pm
PaulB
I did rule out any tyre issues with a complete change of wheels and tyres, but I will check the pressures.
Post #77089 22nd Aug 2011 3:29pm
JonP
Checked my pressures but still humming on low revs anywhere between 30 mph upwards and 1500 to 2000 rpm I'm going to a gearbox specialist Friday for an oil and filter change and to check if there's any signs of early failure of the torque convertor
I think this might be expensive Big Cry
Post #77148 22nd Aug 2011 8:18pm
