![]() | Home > Technical (L322) > Vibration at around 40mph.......Diff problem? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Please note � The following applies to the ZF 5HP24 transmission fitted in the �02-�05MY 4.4 BMW V8 L322. The GM 5L40-E transmission fitted in �02-�06MY 3.0 TD6 and the ZF 6HP26 transmission fitted post-�06 (to both petrol & diesel models) will have different characteristics.
The 56mph �rule� still applies even with the cruise control activated (see measured result below). If the cruise control is activated below 56mph the LUC will be in continuous slip mode (where its application pressure is modulated according to engine torque to maintain a continuous slip speed of around 3%). Above 56mph the LUC will be locked solid.
If you find a clear road and accelerate as gently as possible holding a constant throttle position and you don�t notice any difference to the noise/vibration when you pass through 56mph then I think it�s unlikely to be the torque converter causing the problem. At 70mph on the motorway the LUC should definitely be locked solid (if you release the throttle a small amount the engine revs should stay constant and not suddenly drop) Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Thanks for your input Phil.
Hi Paul,
so possibly you wouldn�t expect a failure of the �continuous slip� system to have quite as severe an effect (in terms of transmitting engine vibration) as it does for the V8. I suppose it�s possible, though, that your TV damper may have failed? Unfortunately I�ve never taken any measurements from a TD6 so I�m afraid I can�t advise what the shift map for the LUC is. In L322 the 5L40-E is, of course, infamous for wear failures resulting in the solenoid which controls the torque converter LUC :
providing inappropriate pressures which leads to the lining of the LUC wearing away (as can be seen in the top photo) dumping more & more metallic debris into the system and ultimately failing the transmission through valve block issues. The first thing you should always do if you have problems with a 5L40-E, therefore, is to check for metallic debris (�glitter�) in the fluid. At that point fluid changes may alleviate the symptoms slightly but won�t tackle the root cause (i.e. it�s already too late) and a transmission rebuild/swap is the only solution. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
phil are you the famous 'phil' from the rangeroversnet site that rebuilds gearboxs .. |
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 ![]() ![]() |
I think he is Scarey |
Ermm, yes � but I�m pretty sure that I�m not famous |
you defo know your stuff mate..welcome ... |
Thanks for taking the time to explain Phil. |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Finally got out for a long drive around Anglesea and much of north wales the other day and the vibration is still very much there.. after I though I'd fixed it with the tire pressures |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Hi Jon, Sorry I've been away and have only just caught up on forum posts ![]() The official diff recall was carried out having previously had 2 earlier attempts at solving "diff issues" so it definately wont be that! When I first had the car it appeared to have the symptoms you are referring too and it turned out to be "cupped" Goodyear tyres ![]() ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
"cupped tyres" are often caused by worn shocks. If that is the cause of cupping, fitting new tyres will eventually result in the new tyres getting cupped as well, unless the cause of the original problem is rectified. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
Just an update following fluid and filter change last Friday
In this instance I dont believe that to be the case as the cupping was evident on the Goodyears at 30k miles, I then changed to the Michelins and did 40k on that set without any "cupping" - If there was an underlying problem that caused the cupping it would have show itself over that 40k miles or the subsequent 35k. Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
