Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 10 of 14 <123 ... 91011 121314>
x7mpp
Do you have the info for carrying out the hardwired method? I'm soon to go home on leave and want carry out the fitting of paddle shifts.
Post #77518 25th Aug 2011 10:46am
stonosam
Australia
Hi Baben,
On the plug and play side do you have to do any modifications to the wiring of the plugs themselves or do you simply plug them in and enable with faultmate?
Car is a 2010 autobiography
Post #77654 26th Aug 2011 2:50am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
You have to make sure that you buy the paddles complete with the 4-pin cable that plugs into the RHS switch pack, then all you do is enable the paddles under "gear selector steering wheel mounted" in "miscellaneous and unused" with the faultmate.
If you can't get the dealer to supply the cable, just get one from a computer hardware supplier. If you go this route, note there is a key on the receptacle on the paddle and on the switch pack. The cable is not one-to-one, it is reversed.
Post #77655 26th Aug 2011 4:39am
stonosam
Australia
Thanks much appreciated
Post #77892 28th Aug 2011 5:35am
stonosam
Australia
Has anybody tried these as a straight plug and and play on a 2010
http://www.ebay.com.au/itm/Range-Rover-L32...0225826126
Post #78033 29th Aug 2011 2:02am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
That's what you need although in the UK they are actually cheaper from the dealer! Shocked You then need to enable the paddle shift feature using a faultmate or similar as stated in Baben's comments higher up the page!
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #78040 29th Aug 2011 7:59am
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Can this paddle shift retrofit be carried out on a 2007 TDV8 Vogue?.
Sorry if this has been asked and answered already?.
Post #83615 24th Sep 2011 10:01am
daveo
when me and matt came up with this upgrade it was meant for the early l322 but will work on any model apart from the 2010 as they were made with them in mind, if you have the the up and down shift on your gear stick as you will it will work, V8 facelift Range Rover Autobiography 22" wheels.
Post #83654 24th Sep 2011 7:46pm
stonosam
Australia
I just took my car to my dealer to check out the possibility of fitting paddles to my 2010 car. They said that it is no problem to enable the ccf and fit the paddles. The only issue is that there is no cabling from the steering. They said that they can create a harness, but it will require 3h of labour to create and fit. So looks like it is not just a plug and play. What have I missed?
Post #84310 28th Sep 2011 7:37am
stonosam wrote:
I just took my car to my dealer to check out the possibility of fitting paddles to my 2010 car. They said that it is no problem to enable the ccf and fit the paddles. the only issue is that there is no cabling from the steering. They said that they can create a harness but it will require 3h of labour to create and fit. So looks like it is not just a plug and play. What have I missed?
about 10 pages... Very Happy Wink ... - .- -.
Post #84312 28th Sep 2011 7:51am
stonosam
Australia
Funny, but my car is the latest version pre the STD fit paddles so according to Baben it's just a plug and play. So arguably I have not missed 10 pages just a bit of wiring. Laughing
Post #84325 28th Sep 2011 8:30am
Ajay(UK)
I think that maybe it's your dealer that needs to read a few pages Confused
According to Baben a 2010MY doesn't need any additional wiring, just plug the 4 pin cable from the paddles onto the spare socket on the steering wheel and enable CFF. Thumbs Up
I must admit I didn't think the dealers were capable of changing the CCF but maybe on a 2010MY that has now changed Very Happy
Post #84331 28th Sep 2011 8:54am
carlos50
Has anyone on here done this to the facelift 2007 MY yet then?. If the steering wheel has the paddles fitted already, a 2010 MY wheel, does this overcome the slip ring issue?.
Post #87563 15th Oct 2011 3:52pm
stonosam
Australia
Hi Guys,
Fitted paddles today to MY10 car, but they are not working? I plugged the cables into the socket and power going to them since they are illuminated. Enabled paddles via Faultmate. Any ideas?
Best
Stonosam
Post #88257 21st Oct 2011 8:17am
Baben
Did you get any further with this after I sent the software versions?
Post #96876 9th Dec 2011 4:16pm
