Home > Technical (L322) > Bluetooth Phonebook Transfer - Android
dan_uk_1984
I feel slightly stupid asking this question, so feel free to flame me. I did search, but no posts seemed relevant (except the post that MICK will no doubt dig up and post in 30 seconds time whilst waiving an accusatory finger at me!)
When I connect my Galaxy S2 (android) to the car it asks for the pairing code every time - on a Nokia you can set something as an "authorised device" I cant find that option in my phone.
As for a RR related question though, the phonebook doesn't transfer. Should this be instigated by the car or the phone? ie should the car say "I want your phonebook" or should the phone say "here, have my phonebook"?
Confused
Post #75716 11th Aug 2011 2:39pm
i think you need to have the bluetooth on the phone on all the time to get the auto pairing...[i think]
Post #75717 11th Aug 2011 2:44pm
dan_uk_1984
It is, then when I get in the car it prompts me to connect.
I dont know why I dont just buy an iPhone! Big Cry
Post #75726 11th Aug 2011 3:12pm
found this dan, it relates to an iphone but might be relevant to yours as well..
http://www.fullfatrr.com/forum/topic3216.h...ne+pairing
and yes , get an iphone.. Wink
Post #75729 11th Aug 2011 3:17pm
Yes, follow the herd Laughing .
Post #75735 11th Aug 2011 3:46pm
pistebeast
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi Dan....don't know if this helps - i've got a galaxy s and mine pairs with no problems (I do have a MY10 - 60 plate)......I went in to - settings - wireless and network - bluetooth settings - scan devices....it then picked up LAND ROVER and asked for pairing code etc and I paired from there....only dropped out once since,
cheers
pete
Post #75736 11th Aug 2011 3:50pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
cant tell you too much about the connection issue.
But about the phonebook:
In the 06 when they were delivered it was only possible to access the phonebook if the phone was in this cradle in the console. (only nokia phones fitted.. quite old stuff now)
Over bluetooth it says in the manual it is not possible.
An update from the nokia Module or a new Module (2010RR or D4) makes it possible.
got the upgraded module and it even shows the signal strengh and the provider name
I forgot: When I first installed the new module my HTC HD2 didnt work with the module.. But as I knew I will buy the Iphone 4 I didnt care.
Post #75737 11th Aug 2011 3:51pm
sleepezy
Dan, I believe the bt module will only save and subsequently auto connect to a limited number of devices (8 from memory). Once you've connected eight units then it's 'memory' is full and no more will auto connect. You can't delete phones from the bt module and the only way I know of to get it working correctly is to replace, and presumably update at the same time, the bt module.
I presume wiggs' reprogramming of the device would clear it - but gather he's no longer doing the upgrades unfortunately. The updated bt module will also allow the address book transfer over bt. The older devices don't support this.
Post #75781 11th Aug 2011 8:12pm
Re: Bluetooth Phonebook Transfer - Android
Laughing Laughing Laughing
Not at all , i remember when i had the FFRR TD6 and i used a Nokia N80 (i think) the phone connected straight away as soon as i went into the car , but when i got the SC i had to connect it manually all the time via pairing , and it has been the same with the last nine or so phones including the Censored i-phone Laughing also it won't transfer the phonebook across via bluetooth.
So i just use the phone in the cradle with a Nokia 6230 IIRC and if someone calls me on the iPhone i just get it to divert to the Nokia in the car.
I'm sure Wiggs has stuff that can over ride your problem Thumbs Up ====================================
Post #75783 11th Aug 2011 8:27pm
dan_uk_1984
You guys are the best!
So to summarise:
- it's only possible to do via the cradle and only old phones fit in said cradle...
- I can buy a newer BT module which will allow all sorts of goodness to happen...
- Or I can make do with it as it is...
Hmmm, thanks guys. Has given me things to think about...
Post #75796 11th Aug 2011 9:08pm
supershuttle
I've got an Android (HTC Desire) phone and I got an exchange BT module off Wiggs. I pretty much get full functionality over bluetooth, except for sending and receiving texts.
Phone book uploads fine, all Missed calls, Dialled calls and Received calls are also logged, - I just have the phone in the armrest with a USB power connection from the rear socket and everything is controlled from the steering wheel, or you can use the touch screen - you can even do it all from the phone but that kind of defeats the object.
Job Done Thumbs Up Geoff
Post #75800 11th Aug 2011 9:28pm
supershuttle
and it pairs automatically Geoff
Post #75801 11th Aug 2011 9:29pm
dan_uk_1984
Will any module up to and including 2010 work?
Post #75805 11th Aug 2011 9:39pm
supershuttle
Mine had a BT module in (2007 model) but it was unreliable and I had pairing problems and it didn't transfer the phone book or the call records, I can't say what works and what doesn't. However if you can borrow one they are only a two minute job to swap and test. Geoff
Post #75810 11th Aug 2011 9:43pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Ha, Dan, this is quite funny, I was JUST about to ask the same question!
Paired my blackberry but can't see the contacts and won't import either.
Where can I find the updated module and how much $$?
Thanks.
Post #75821 11th Aug 2011 10:15pm
