Home > Technical (L322) > Bluetooth Phonebook Transfer - Android
sleepezy
Stryke - Wiggs used to do the new bt on an exchange basis but has stopped doing so recently (I believe) unfortunately
You can get a replacement latest model from the dealer which I think costs �140 but I am not sure.
I should say my limited knowledge is based on a 2007 model (ie mine!)
Post #75831 11th Aug 2011 10:42pm
Jsb
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
http://www.fullfatrr.com/forum/post48486.html#48486
Post #75840 11th Aug 2011 11:12pm
wiggs
I am doing the exchange bluetooth modules again . Thumbs Up
Basically 2008MY and onwards will give you phonebook over bluetooth ....any earlier and you either need a software upgrade ( my bluetooth exchange ) or a new module
bluetooth exchange modules also cure any pairing issues Very Happy
Post #77704 26th Aug 2011 1:39pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi wiggs
How much are you charging for the exchange, i have a 2007 model 56 plate TDV8, my BT will connect fine but not auto connect and sync the phonebook over BT.
Carl
Post #77715 26th Aug 2011 3:42pm
wiggs
�60 for the exchange service Thumbs Up
Post #77742 26th Aug 2011 7:19pm
supershuttle
carlos50 wrote:
Hi wiggs
Carl
I've got the same car and a HTC Desire, the exchange unit from Wiggs works a treat. Phone book, missed calls, dialled calls and received calls all upload fine. Geoff
Post #77752 26th Aug 2011 10:16pm
Googsy
Slight deviation from subject chaps I have a 2008 model and pairing etc works fine with my HTC Desire . Issue is everytime I connect some numbers from phone are duplicated and appear sometimes 3 times. Does blutooth take contacts from phone and sim? Im thinking i need to delete my sim contacts if so and just have on phone ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #77766 26th Aug 2011 11:11pm
wiggs
the bluetooth module will only take numbers from the phone ....not the sim
Post #78277 30th Aug 2011 3:42pm
supershuttle
And if you have more than one number associated with a name it only picks up the first. Geoff
Post #78280 30th Aug 2011 4:26pm
