Home > General > whos fitted an aftermarket satnav
Page 1 of 3 123>
pretlove
has anyone on here fitted one of these
if so i have a couple of things to ask
first off on the original plug there are two connectors at the bottom that don't appear to do anything when connected to the new system is this for the cd multi changer if so i take it that it will not work with the new system...
second question does the multi changer have a standard aux lead that i can connect to the new unit
also if anyone is after one of these units i managed to get mine for £325 and that includes the map software ....unlike the ones sold by ?uk that want £525 and yoou then have to pay £40 for the map software "RANGEISM WILL NOT BE TOLERATED"
Post #70805 1st Jul 2011 2:53pm
in the 'in car electronics' section
http://www.fullfatrr.com/forum/topic6206.html
loads of info re maps here
http://gpsunderground.com/forum/forum.php
Post #70808 1st Jul 2011 3:23pm
iowdave
United Kingdom 2004 Range Rover HSE Td6 Epsom Green
i think the price is good .i did the range rover set up in mine but if id of seen these id probly had one i like the look of them..
Post #70815 1st Jul 2011 3:55pm
pretlove
thanks scarey ....i knew id seen it somewhere but im no good with search function Embarassed i did try "RANGEISM WILL NOT BE TOLERATED"
Post #70822 1st Jul 2011 4:22pm
grant
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Pretlove is yours an HSE?
Post #71711 8th Jul 2011 2:14pm
grant , click on pretloves little car and all will be revealed.. Wink
Post #71713 8th Jul 2011 2:21pm
pretlove
yes grant it is but mine for some reason has an amp in the rear allthough this didnt effect the install at all...as posted in my range rover thread its all up and running now just got to sort out the reverse cam and maybe a couple of other bits Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #71738 8th Jul 2011 5:53pm
grant
U little little legend Stan Bow down
Post #71756 8th Jul 2011 9:01pm
grant
I was asking if it was an HSE because of the Sat Nav, Steering wheel controls are different etc.
Post #71757 8th Jul 2011 9:03pm
pretlove
i thought the steering wheel controls are the same other than the fact vogue's and above have the heated steering wheel,
these aftermarket units are only any good if you have a hse "RANGEISM WILL NOT BE TOLERATED"
Post #71771 8th Jul 2011 10:28pm
SteveMFr
Site Sponsor
Did you keep the MID for the BC functions?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #71878 10th Jul 2011 11:02am
pretlove
yes ive just fitted that in the glovebox today .... Thumbs Up
i want to get a black bmw mid so i can fit that and do a tidy job but at least its in there and all the wires are there ready. "RANGEISM WILL NOT BE TOLERATED"
Post #71892 10th Jul 2011 1:43pm
993porky
England 2004 Range Rover HSE Td6 Java Black
Hi pretlove did it take much fitting is it all plug an play wouldn't mind one myself for my hse also is the mid wiring long enough to re route to glovebox from dash? Range rover hse
Java black
Post #71925 10th Jul 2011 10:08pm
pretlove
pretty much plug and play porky i did a bit more triming of the plastic than powerfull say to do as i still wanted it to sit back further ...the mid wiring loom is plenty long enough you just have to undo it a bit from the origional stereo/mid loom....getting the multichanger out is the worst job as a lot needs to be unbolted
heres a pic for you of the finished install[/img] "RANGEISM WILL NOT BE TOLERATED"
Post #71932 11th Jul 2011 1:20am
993porky
Pretlove it looks a great fit am very impressed with that looks much better than mid I have could you PM the full details off where you bought it, prices, model number etc and additional photos during fitting if you have any.
Any advice and help would be great so I can do an exact coPy of yours.
Could you plug iPhone or iPod in to that unit aswell?
Cheers Paul Thumbs Up Range rover hse
Java black
Post #71996 11th Jul 2011 2:40pm
Page 1 of 3 123>
