Home > General > whos fitted an aftermarket satnav |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
has anyone on here fitted one of these
1st Jul 2011 2:53pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
in the 'in car electronics' section
1st Jul 2011 3:23pm |
iowdave Member Since: 03 May 2011 Location: isle of wight Posts: 38 |
i think the price is good .i did the range rover set up in mine but if id of seen these id probly had one i like the look of them.. |
1st Jul 2011 3:55pm |
thanks scarey ....i knew id seen it somewhere but im no good with search function i did try "RANGEISM WILL NOT BE TOLERATED"
1st Jul 2011 4:22pm |
grant Member Since: 06 Jun 2011 Location: Dunmow Posts: 24 |
Pretlove is yours an HSE? |
8th Jul 2011 2:14pm |
grant , click on pretloves little car and all will be revealed.. |
8th Jul 2011 2:21pm |
yes grant it is but mine for some reason has an amp in the rear allthough this didnt effect the install at all...as posted in my range rover thread its all up and running now just got to sort out the reverse cam and maybe a couple of other bits "RANGEISM WILL NOT BE TOLERATED"
8th Jul 2011 5:53pm |
U little little legend Stan |
8th Jul 2011 9:01pm |
i thought the steering wheel controls are the same other than the fact vogue's and above have the heated steering wheel,
8th Jul 2011 10:28pm |
Did you keep the MID for the BC functions?
10th Jul 2011 11:02am |
yes ive just fitted that in the glovebox today ....
10th Jul 2011 1:43pm |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 |
Hi pretlove did it take much fitting is it all plug an play wouldn't mind one myself for my hse also is the mid wiring long enough to re route to glovebox from dash? Range rover hse
10th Jul 2011 10:08pm |
pretty much plug and play porky i did a bit more triming of the plastic than powerfull say to do as i still wanted it to sit back further ...the mid wiring loom is plenty long enough you just have to undo it a bit from the origional stereo/mid loom....getting the multichanger out is the worst job as a lot needs to be unbolted
11th Jul 2011 1:20am |
Pretlove it looks a great fit am very impressed with that looks much better than mid I have could you PM the full details off where you bought it, prices, model number etc and additional photos during fitting if you have any.
11th Jul 2011 2:40pm |
