Home > Technical (L322) > 6HP28 Possibly Juddering
Page 3 of 3 <123
RRPhil
Hmmm. They’ve sent you the 1068 298 047 solenoid kit for the E-shift 6HP28. I wonder why they’ve done that? They must know you have the M-shift version because you ordered the 063 intermediate sheet. Strange.
The 3 x yellow cap, 2 x blue cap and 2 x orange cap solenoids are all identical for your M-shift, so that’s fine – it’s just whether they’ve charged you more than they would have done for the correct 1068 298 046 solenoid kit? Maybe they didn't have an 046 kit in stock so they've sent you the 047 kit for the same price?
Phil
Post #680392 15th Dec 2023 3:49pm
dhallworth
That makes perfect sense now!
The part number on the box for the solenoids is 1068 298 046 but the contents seem to match 1068 298 047.
I’ve checked the invoice and it’s been billed to me as a 046 kit.
I’ve called them and made them aware of what I’ve had delivered. Have told them I’ll use the solenoids and if they want the rest of the kit back they can arrange to have it collected.
They seemed happy enough with that and will come back to me on Monday.
Post #680395 15th Dec 2023 3:59pm
RRPhil
Post #680397 15th Dec 2023 4:04pm
dhallworth
Another question I’m afraid, Phil.
Is there a tightening sequence and torque figure for reassembling the valve body?
Thanks,
Post #680425 15th Dec 2023 9:31pm
RRPhil
I don’t think I’ve ever seen any documentation regarding the tightening sequence for the 17-off M5 x 40 screws which hold the two valve bodies together, plus the 5-off M5 x 55 screws which bolt the electronic module to the hydraulic module.
The standard torque setting for this size and grade (i.e. 10.9) of screw is 8.3Nm, but maybe this sounds a little high for the aluminium castings?
The larger (M6) screws which bolt the assembly to the casing are specified at 8Nm (+/- 0.8Nm), so I think probably 6Nm for the M5 screws? In terms of tightening sequence, I think that the ‘start in the centre and work outwards in a spiral’ rule applies.
Phil
P.S. I note that the Sonnax instructions for their 6HP28 Mechatronic Zip Kit states “Mechatronic-to-Case or Valve Body Halves Bolts 8Nm/71 in-lb” so, clearly, they feel 8Nm is suitable for both the M6 and the M5 screws.
Post #680430 16th Dec 2023 1:13am
RRPhil
For the sake of completeness, this is the tightening order for the screws which bolt the Mechatronic unit into the casing. Yours will be the later 13 screw design (i.e. 10-off M6 x 59 plus 3-off M6 x 20):
Earlier transmissions used just 10 screws :
Tightening torque for these M6 screws, as mentioned in the previous post, is 8Nm (+/- 0.8Nm)
Phil
Post #680486 16th Dec 2023 6:32pm
dhallworth
Thanks Phil. Really appreciate you posting those diagrams.
I’m hoping to get to it this week, otherwise it’ll be after Christmas unfortunately.
Post #680597 18th Dec 2023 2:55am
dhallworth
All dampers replaced along with the intermediate plate and all solenoids.
Gearbox is silky smooth changing through all gears now. Haven’t had a chance to take it onto the motorway yet or get it on cruise.
Adaptions were also reset so need a couple of hundred gentle miles of up and down the gears. I’ve never had much luck doing the proper drive cycles. I’ve never been able to find a road long enough to let it coast almost to a stop.
PM incoming about returning your solenoids, Phil.
Post #681270 27th Dec 2023 10:06pm
Mikey
My 1st-2nd gear change when cold isn't as smooth as I'd like it to be. And the sump is leaking
Guess what I'll be doing next Laughing
Post #681296 28th Dec 2023 10:20am
toronnoRR
Canada
Hi Dhall,
I've read through this post with great interest! I'm wondering how your transmission is after 6 months now?
Post #693224 24th May 2024 4:40am
dhallworth
It’s perfect Smile
Gear changes are silky smooth and it’s behaving perfectly.
I’ve done some towing with it too which included moving a car on the trailer from North Wales to Glasgow which was a 700 mile round trip, 350 miles of which had an empty trailer (900kg) and 350 miles had a loaded trailer (2500kg) and it performed perfectly.
Still can’t thank RRPhil enough for his help with this one.
Post #693228 24th May 2024 7:52am
RobWCanada
Canada 2011 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
Hey, I know this thread is from last year but it’s great! I thought I had the same issue as you, sounded like the exact same symptoms but I cleaned the MAFT sensors and 200km and it hasn’t re-occurred (fingers crossed).
However, I have the GAP tool and was recording my turbine and engine speed like you did but I’m not sure how you managed to get the two RPM axis to line up. When I try to graph it they don’t sync up because the engine RPM seems to be variable axis and the turbine is static. I see you got little triangles on the legend…did you somehow lock the axis together?
R 2011 Range Rover L322 SC - Autobiography (Ipanema Sand)
Ontario, Canada
Post #716805 26th Apr 2025 4:34am
RRPhil
Unfortunately, I have no experience using the IIDTool so we’ll need to wait for David’s response. Just to point out, though, that the data can be exported to a .csv file and then plotted in Excel, which then makes it very straightforward to plot both sets of data on the same speed axis and time axis for comparison purposes.
Phil
Post #716885 27th Apr 2025 10:51am
RobWCanada
Ya for sure. I can try that but let’s see what David says he seems to have managed to do it…unless he was just very gentle on the accelerator and only went to 2500 rpm…hmm 2011 Range Rover L322 SC - Autobiography (Ipanema Sand)
Ontario, Canada
Post #716918 27th Apr 2025 5:54pm
dhallworth
It's a while since I did this, however, from memory, if you your phone to landscape (I use an iPhone) and touch the scales on the left hand side you can slide then up and down to get them closer together. You can also pinch and zoom to change the scale on the right hand side.
I likely won't be in my car until next weekend now but if you've not managed to sort it out beforehand I'll connect up my IID tool and take a look.
Post #716940 27th Apr 2025 9:53pm
Page 3 of 3 <123
