![]() | Home > Technical (L322) > 6HP28 Possibly Juddering |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
Hmmm. They’ve sent you the 1068 298 047 solenoid kit for the E-shift 6HP28. I wonder why they’ve done that? They must know you have the M-shift version because you ordered the 063 intermediate sheet. Strange.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
Another question I’m afraid, Phil.
I don’t think I’ve ever seen any documentation regarding the tightening sequence for the 17-off M5 x 40 screws which hold the two valve bodies together, plus the 5-off M5 x 55 screws which bolt the electronic module to the hydraulic module.
For the sake of completeness, this is the tightening order for the screws which bolt the Mechatronic unit into the casing. Yours will be the later 13 screw design (i.e. 10-off M6 x 59 plus 3-off M6 x 20):
Thanks Phil. Really appreciate you posting those diagrams.
All dampers replaced along with the intermediate plate and all solenoids.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
My 1st-2nd gear change when cold isn't as smooth as I'd like it to be. And the sump is leaking
toronnoRR Member Since: 26 Feb 2024 Location: toronto Posts: 15 ![]() ![]() |
Hi Dhall,
It’s perfect |
RobWCanada Member Since: 24 Mar 2025 Location: Ontario Posts: 3 ![]() ![]() ![]() |
Hey, I know this thread is from last year but it’s great! I thought I had the same issue as you, sounded like the exact same symptoms but I cleaned the MAFT sensors and 200km and it hasn’t re-occurred (fingers crossed).
