Home > General > What Did You Do In Your Full Fat Today
Page 381 of 381 <123 ... 379380381
Foxie
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
...Finally Cast Aside the 22" Turbines and Conti's.
20" 'Thong' Style 5084's added with 285/50/20 Cooper AT3 Sport2 Rubber.
The ride has been improved beyond belief,: more importantly I can venture into our Steep Cornish fields with far far less concern.
Very Happy 2014 SDV8 4.4 Santorini AB
Lamborghini C305S
Hanix H36A
Hanix RT300
Post #714992 27th Mar 2025 6:13pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Had the lads from autoglass round to replace my screen and they couldn’t get the n/s wiper off the spindle, so had to put it back together until I can get it shifted.
Censored Big Cry
Post #715006 27th Mar 2025 9:48pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Fatty is at the LRJ dealer, safety recall N 897, passenger airbag replacement.
I can already see the trouble I'll be in afterwards, because every time a garage gets its hands on it, things just don't work properly any more.
Post #715027 28th Mar 2025 8:46am
JoolsB
Spent a couple more fruitless hours trying to get the wiper arm off the spindle so I can have my new windscreen.
I’ve got another puller coming tomorrow and if that doesn’t work, I’m going to have to cut it off and get a new wiper arm.
Post #715150 29th Mar 2025 10:49pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Transfer case oil change. Far easier than I expected. The oil was darker than I expected too. I suppose it has a clutch, so it's quite different to the front and rear diffs. I'm keen to get on and change the gearbox oil now! (But I am waiting on parts).
Post #715187 30th Mar 2025 12:02pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Got confirmation that the warranty on my car is going to pay for the front crankshaft oil seal, pulleys and tensioner, as well as new belts and the labour.
The garage are also going to fit a new rear ride height sensor, which will cure the bouncy ride I was getting occasionally.
It’ll be nice to drive it again !
Post #715277 31st Mar 2025 3:47pm
TomC-RRV8
Changed the front upper arms and track arms on the front today on both sides as well as the bastard ball joints they took some pounding, heat and more pounding to get them out. All back together test drive complete rides much better. However, ns wheel is now caked in grease, seems I must have nicked the CV boot, massive headache...... now have to sort that it never rains it pours!!!! Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #715298 31st Mar 2025 8:28pm
JonnyCJ
Got it back from the Indy after having all the pulleys, tensioner, idler thingies, belts and crankshaft oil seal changed. Winced at the £1,800 bill which I didn’t have to pay and felt for the chap I got the car from who did cough up.
Got home with the same boncy suspension fault which the new ride height sensor hadn’t cured and spent a bit of time looking up the “suspension will raise when system has cooled down” message.
Put another coat of high build primer on the dog guard and mounts (see separate thread). Fitted the new hedgehog and confirmed blower speeds work as they should, so popped the panels back on.
Started polishing the piano black door trim, ready to fit to my new to me ivory door card.
Test fitted the dog guard mounts and got a bit excited when it looked like they’ll fit in a 2012.
Having a break and will continue a bit later….
Post #715362 1st Apr 2025 7:31pm
JoolsB
Finally got the wiper arm off with the grinder and some violence, new arm ordered to fit once autoglass have been back.
Does anyone know the size or part number for the grommet that goes on the wiper spindle where it passes through the scuttle, can’t seem to find it anywhere and mine has suffered ‘collateral damage’.
As ever, what appears to be a routine job turns into a saga, it was quicker and less stressful doing the oil cooler.
Post #715372 1st Apr 2025 9:48pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Just found this 😫 no idea how it happened. Rich
Post #715400 2nd Apr 2025 10:50am
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Changed the oil and filter this morning and air filters. Used an oil extractor vacuum pump, what an excellent bit of kit. Took out 9 litres, refilled with 8 litres, then warmed her up checked again, topped up half a litre took it for a 10 minute drive, checked again and oil level spot on. Also calibrated the suspension, all nice and level.
Post #715617 5th Apr 2025 7:03pm
JonnyCJ
Installed the 2003 dog guard in my 2012 - yes it can be done ! Changed the rotary gear selector topper, see tips on using a screw to pop the old one off. Cut out the old shonky wiring repair to the top of the offside front shock and re-wired with proper soldered connections and heat shrink tubing.
Used the new key fob the RAC provided yesterday. For those of you with a single key, if you have an RAC membership or insurance that covers lost keys, go ahead and claim. 15 mins to programme a new key and cut the blade. Total cost - £0 and doesn’t affect your insurance.
Tidied up some electrician’s tape repairs under the bonnet, with correct cable ties.
A quiet day today.
Post #715621 5th Apr 2025 7:15pm
JonnyCJ
Installed DAB+ and bounced down the road to drop it off at the garage to get the suspension issue sorted.
Post #715666 6th Apr 2025 4:20pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Sprayed rear subframe, diff etc with phosphoric acid yesterday. All rust turned black. Sprayed Lanoguard today. 30 minute job took 2 hours! Blocked filters, non-performing trigger, had 3 different sets including one I bought last year. I quite like the product, hate the hassle and mess created by the rubbish squirty bottles. 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #715730 7th Apr 2025 7:00pm
hmallett
I towed a stock trailer to collect 27 bales of hay!
I then tried to change the gearbox oil, but failed at getting the gearbox bracket off - 3 bolts were accessible with a socket, and could be loosened, but the fourth bolt has the front driveshaft in the way of a socket, and using a spanner the bolt started to round, so quit while I was ahead.
Post #716044 12th Apr 2025 10:15pm
