Home > My Range Rover > 5 RRs and I have to give up
Page 14 of 14 <123 ... 121314
MarianaWestminster
Great thinking Knares I like it...
The car is a 7A vin so this screenshot from JLR classic parts suggests YWC500521 is correct and a later part number can also be fitted in succession to the original.
Post #715796 9th Apr 2025 6:57am
MarianaWestminster
Been looking back at my pump pressure test and I do see an anomaly.
According to the WSM the relief valve in the pump should limit pressure going to the rack to 114 bar +/- 4 bar so that's a min of 110 bar and max of 118 bar.
During my pressure test I saw 1750 psi or approx 121 bar.
This is higher than the specs though?!
Also the pump itself is marked with a sticker stating 132 bar?
Post #715896 10th Apr 2025 11:15am
MarianaWestminster
Does anyone know exactly how much pressure the rack needs?
The 2007MY workshop manual doesn't have the information but I found a 2002MY manual which states I should see 8 bar at idle and 133 bar at full lock. (Screenshot below)
Obviously a 2002MY car has a different pump but I'm sure the rack is the same 2002-2012?
On my pressure tests I saw approx 4 bar at idle and 121 bar at full lock...
Post #716020 12th Apr 2025 11:58am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i cannot make the page big enough to read RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #716047 13th Apr 2025 3:08am
MarianaWestminster
Hopefully this will be better Knares
Post #716051 13th Apr 2025 8:05am
knares
yes, i can read that RR 2005 4.4 petrol
Post #716068 13th Apr 2025 1:09pm
