Home > Maintenance & Mods (L405) > Executive rear seat storage lid fatal demise
Gremlin500
Couldn’t it be repaired properly with piano hinge and pop rivets? Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714886 25th Mar 2025 9:18pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Cheers for that DrF, sounds like I was told some BS by the main dealer, who'd have thought that ? Rolling with laughter Mr. Green
Still going to joey mine 2019 SV AB Dynamic Scafel Grey
Post #714920 26th Mar 2025 11:50am
Stuart-
A lot of manufactuers do that. Especially in the domestic appliance area.
I wonder if its a part worth me having made if it's a common problem? I wouldn't mind seeing a photo of the hinges on their own closer up. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #714924 26th Mar 2025 12:30pm
Mr Tee
If anyone has any ideas for how to joey this , I’m all ears .
Post #714929 26th Mar 2025 1:23pm
Swagman
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Siberian Silver
I've removed the arm rest from the car to have a better look at it
The plastic hinge is what has shattered, these plastic hinges used to be moulded around the silver elements on the long bar that runs through the entire assembly, as the arm rest and the under tray both pivot off a central thin bar running through the centre.
Those silver elements are 'really' hard to turn, so much so that you cant do it by hand and have to use pliers to even turn them, I've soaked them in WD40 for a day and still they have very little movement, I suspect it was designed with some resistance as you wouldn't want the armrest to fall back down on your fingers once opened, but there seems to be far too much resistance for a thin plastic hinge to survive, so I guess over time, the leverage of the length of the arm rest and the stiffness of the silver element had a weakening effect till it jammed and stopped moving and snap.
The two little bits are what I found in the recess below the arm rest once it had been removed.
I've tried epoxying it back together, I didn't give that much hope and I was correct, a couple of movements and, it came apart again.
Anyway this is just for knowledge.
** You'll have to click gallery below to see photos they didn't attach to the message **
Post #715116 29th Mar 2025 5:01pm
Swagman
and my solution.
was to metal cable tie the remnants of the hinges on the arm rest to the metal hinge of the pivot bar, which you can see in the photo in my 'Gallery'
Post #715336 1st Apr 2025 11:56am
