![]() | Home > Maintenance & Mods (L405) > fuel tank guard cradle |
minim Member Since: 15 Mar 2024 Location: Bergen Posts: 35 ![]() ![]() ![]() |
I will make mounts for the original heat shield so I can reuse that.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1457 ![]() ![]() |
Soooooo ... I'm watching your efforts with interest.
I have had the same thoughts about the saddle section. A and C I assume is the reason. Having 2x 35x6mm bars bent over there should do the trick then. The rigidity I'm a bit worried about but then again the tank on many other cars are just held up by straps.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Interesting project, my question is why given you can buy one….. There is nothing that can't be fixed with a hammer😜😜
I really should not lol. I'll try some excuses |
Slowly progressing. I cut out the tunell today and bended the two bars going front to back. Welded the left side so now the tank is hanging on its own on that side. Will make the other side before I start on supporting the other tank sides and making mountings for heatshield and aluminium skid plate.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8520 ![]() ![]() ![]() |
That's coming along, should do the job... |
Not much time to work on the car these days but had a few hours today. The braces are almost done. Need to add something reinforcing the rear and all the mounts for the heat shields and alu under the car. Tunnel is still undecided. Hope I get time to complete it tomorrow and paint it.
Completed both sides today. Total 12 fixing points per side including mounts for the protection that will go under it. In the center the mounts are placed so the original heat shield fit. Will make a center section tomorrow and I might have to modify the sides slightly for that to fit. Hope I get it done tomorow and paint them.
Looking good... |
And first coat of paint is applied. The alu covers will be welded once I mount these later.
They are looking very good V8 or else ... |
Thank you!
