Home > Technical (L322) > 4.4 TDV8 Slow coolant Leak Fix
Page 2 of 3 <123>
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
4.4 tdv8 will leak coolant over time, it is not a matter of if but when.
Likely coolant leaks come from:
- Oil cooler
- EGR cooler hose 'o' Ring
- Thermostat housing
- Various hoses with connectors to thermostat housing
etc SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #647235 3rd Nov 2022 8:04pm
GraemeS
Australia
Mine's top hose o-ring is now a snug-fitting 45 mm x 3.5 mm in Viton75. A slightly smaller supposedly 45x3.5 but suspected BS224 pair were first supplied which I didn't try but today found to float excessively in the housing prior to fitting a real 45x3.5 sourced from a different supplier to the bearing retailer.
Post #648302 16th Nov 2022 11:43pm
GGDR
- Oil cooler
etc
I have some coolant dripping down the back of the bell housing.
Where should I go first? EGR?
. Cheers, Greg
Post #684053 27th Jan 2024 6:18pm
JayGee
It's a possibiliy but an inspection with an endoscope will confirm. Mine's been leaking from the EGR cooler for 2+ years and I just keep topping up the coolant as the cost of replacing the EGR cooler is not worth it. If it gets worse I'll have to have it done but so far it's been just a contant small leak. 2012 TDV8 Vogue (L322)
Post #684087 28th Jan 2024 9:32am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
GraemeS can you confirm the size for both the stat housing pipes is 45X3.5 , mines slightly seeping and if i'm draining it down a bit I'll do both of them , agree with a list of oring sizes would be a very useful wiki .
Ta
Post #686544 26th Feb 2024 11:13pm
GraemeS
Australia
Both are indeed the same size.
Post #686549 27th Feb 2024 2:04am
Dolphinboy
SpitfireS wrote:
Oh I wish my (2012 4.4 TDV8) slow coolant leak would be fixed with cheap o-rings.
But it turned out to be the oil/coolant heat exchanger.
Big Cry
Could also be the EGR cooler.
Post #686590 27th Feb 2024 11:58am
Range Rover L322
I am just tagging on here as I also have a slow coolant leak which we cannot diagnose (2012 4.4 TDV8)
I have an endoscope (1pc 2MP Endoscope Camera, IP67 Waterproof 8 MM Hard Wire Pipeline Inspection, Borescope With 8 Adjustable LED For IOS Iphone Android) from Temu £20 which is brilliant but through which I can see some red crystals in various places on the left hand block as you look at the engine, along the head gasket . However, without this endoscope I would not be able to see them . I am taking pics over time but the red crystals are not increasing, in fact they are coming off . We have changed the Oil cooler recently as well as the top rad hose LR029140 so it might have been a spill.
I do not have any solutions yet, but I wanted to lend support to the fact we all have slow coolant leaks and it is pretty much normal!
Best, Matt
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #686644 27th Feb 2024 10:09pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
- Oil cooler
etc
Where is the Egr cooler hose o ring located, what about the size? 2011 Vogue SE 4.4 TDV8
Post #713825 11th Mar 2025 7:06pm
Mfcetin
I think I found one of my coolant leaks. It is the hose on the right rear side of the plenum.
I am not sure if there is an o-ring I could replace or I need to change the whole hose.
Can anyone help? what size is the o-ring? or any part number for the hose?
Cheers
Fatih 2011 Vogue SE 4.4 TDV8
Post #713894 12th Mar 2025 1:57pm
Kasandrich
It's reassuring to know I'm not the only one with a minor coolant leak on an L322 4.4tdv8
Post #714188 16th Mar 2025 9:11pm
sako243
In changing the alternator I've noticed the push fit fitting on the bottom of the expansion bottle is weeping slightly so that's another possible source.
Still need to investigate a fix. Ed
Post #714200 16th Mar 2025 9:44pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
You’re not even the only one in Braintree Laughing Mine has a slow leak too.
Post #714206 16th Mar 2025 11:47pm
Kasandrich
Where abouts in Braintree are you? I'm in victoria street right in the town centre
Post #714227 17th Mar 2025 11:15am
Full-fat-Lance
I’m on the fairview estate
Post #714262 17th Mar 2025 6:31pm
Page 2 of 3 <123>
