![]() | Home > Technical (L322) > 4.4 TDV8 Slow coolant Leak Fix |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I had a thermostat housing leak, the housing was replaced but I only needed an `o` ring replaced,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
Similar scenario for the induction pipe to the throttle body. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I also have a very slow leak but cannot see any sign of where it leaks from, despite my best efforts with a torch and standing in the engine bay to investigate. 2015 Range Rover Autobiography 4.4 SDV8 |
Gary, I cobbled together an old expansion bottle cap and an air line connector and put a gentle amount of air pressure in the bottle. I immediately saw a drip from my top hose to the thermostat housing. Can you try the same? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
I just replaced the o-ring in the thermostat housing end of the top radiator hose with what I expect is BS828 (I had several on hand), approx 46mm ID & 53mm OD. A low coolant level warning was occurring every 6 weeks after a top-up and coolant was dripping from this fitting. Not surprisingly the housing with the original seal slipped on and off the spigot very easily, but required a firm push or pull with the BS828 fitted. The bottom radiator hose could have the same fitting but I didn't want to disturb the seal to check and it wouldn't be a quick a task to remove it. Having measured the housing on the top I/C hose (90mm) and the throttle body spigot (81mm), I will obtain a BS620 to try. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I had the radiator degas hose go L405 but same engine - The old o-ring measured 8 x 2mm. A replacement 8x2 didn’t seem like a nice fit, but a 7x2 was really snug.
The L322 doesn't appear to have that fitting but L405 owners seem to have appreciated your information. |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I checked everythng whilst I had the plenum chamber out for cleanig etc. I can report all the push type fitting needed new orings and no further leaks/top up needed since. The hose and push fit seem to be ok, just need 'O rings' SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
Investigate around the thermostat area and go fromt here. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
The top radiator hose has the excuse of continual movement between the thermostat housing and the radiator for wearing its seal and due to the RR being my only form of transport I though best not to disturb joints that are currently sealing. Besides, I needed to get the grass cut before the rain starts again! |
Got it.
Thanks for the confirmation of the sizes. I'll be keeping a check on the sealing of the new o-ring over the next couple of days.
The o-ring size that I fitted is 45mm x 3.5mm, not the previously quoted BS size. I'm trying to get hold of 2 in Viton 75 as nitrile's maximum temperature is a little low. |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 123 ![]() ![]() ![]() |
Oh I wish my (2012 4.4 TDV8) slow coolant leak would be fixed with cheap o-rings.
