![]() | Home > Technical (L322) > L322 Lower Control Arms |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
I fit Lemforder whenever possible although the bush in the front rear arm never lasts long where I drive. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
I think Lemforder were the original ones fitted, I always use them to replace mine and have not had any problems. But.... I only go off road when towing a horse box so the car is treated very gently when off road. Also, if you have the tools and the arms are in good nick, the original Lemforder bushes by themselves are quite cheap. |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 519 ![]() ![]() |
Absolutely correct, if the bolts are torqued up with the lower arms 'hanging' in the air (i.e. with the vehicle jacked up), then they'll wear out really fast as the rubber bushes are abnormally twisted when the vehicle is on the ground and at it's normal ride height. They need to be assembled in the air, and finally tightened with the vehicle's weight on the wheels / hub. Then the rubber twisting action only happens when the suspension is articulated. Lemforder is quality stuff and highly recommended. 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Lemforder is always my go-to brand. I killed some Britpart rubbish in less than 1K in Australia on my 110 Isuzu County. Since then I've always gone with Lemforder. I noticed some lower arm rear bushes the other day (admittedly for a Disco 4), which didn't have the 'hydraulic' design, maybe they're more robust / heavier duty and similar is available for the L322? I can find a link if that helps? Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
So glad to know that I was correct about the sequence to torque up the suspension arms fasteners, which means I got it right this time.......makes a change |
Meyle make HD rubber D3/D4 bushes but D3/D4 bushes aren't the correct size. However early BMW X5 bushes are and HD Meyle X5 bushes are available so I tried a pair for a short while but didn't like the harshness they caused. I had previously acquired 2 different sets of poly bushes which I've not fittted at all after finding the Meyle bushes too harsh. I've resigned to replacing the Lemforder bushes regularly as my best option short of replacing the vehicle with a L405 with IMO their better front suspension design. |
Yeah, I've read that the non-hydraulic (i.e. solid rubber) bushes are a bit harsher - stands to reason really. Didn't realise they were Meyle, not perrsonally keen on that brand. Think I saw them on Advanced Factors website.
The Meyle HD BMW bushes aren't solid. They're of similar design to the LR version but more rubber, less air space and possibly a different rubber compound.
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 90 ![]() ![]() |
I did buy Lemforder from eurocarparts after the Lemforder ones I bought from advancedfactors failed after 3 years. I think the ECP ones were different because they failed within 6 months.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
Borg & Beck Front Lower Track Control Arm Part No BCA6732-PV BCA6732-SJ
this_is_anarchie Member Since: 21 Mar 2022 Location: Essex Posts: 26 ![]() ![]() ![]() |
Thanks for your advice, looks like Lemforder is the way to go by consensus. Haven't heard of the initial assembly then final tighten up on the ground method, noted! 1993 Range Rover Classic 3.9 Vogue
