Home > Technical (L322) > New 2012 Westminster owner, 3 months in after some advice
diabloam
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hi all
Long time Landy person, pretty much all models at some point but always fancied a late tdv8 4.4 L322 and eventually found a superficially good one in Baltic Blue, 133k but pretty clean. Very keen tinkerer and happy to tackle jobs myself and done some biggy's including Disco 3 body off engine changes and such like so happy to get fired in, just want to get some pointers on what I have across on my L322 that I bought in December and has been my daily.
Firstly I have noticed a clonk clonk noise which sure can feel through my arm on centre console. It only really seems to do when turning right whilst pulling away at a junction and otherwise silent and clonk free even when giving it some beans. I am thinking prop or prop bearing possibly, read some posts but was hoping someone has experienced this before and can tell me if my thinking is correct and also, is it whole prop, just bearing or what is the collective experience on this.
Also, it keeps moaning about spare tyre pressure and to check it and another tyre warning about low loads setting on spare or something. Checked spare and iirc its at like 40, so am unsure what its meaning.
And lastly I have an oil leak, seems to be coming down either side round about bulkhead and onto very rear of undertray, is this oil cooler I am sure I have read about? and is there a how to for doing it if people think it mat be that, or is it something else. Can see much from top but only really took engine cover off. Will try add some pics to see if that helps. Added some photos from each side and middle plus undertray. Coming down both side and anti roll bar covered
Any help hugely appreciated, know landys but these are new to me so dont up to speed with issues. Really like it though so planning to keep a while, no rust either and clean for age and miles.
Thanks in advance all
Post #711769 13th Feb 2025 8:48pm
diabloam
Post #711770 13th Feb 2025 8:49pm
diabloam
Also, going to collect up bits for full service. But if I keep eye on oil level and coolant is it fine to continue to use it till have everything I need to fix and service as its my daily, thanks
Post #711771 13th Feb 2025 8:50pm
mjdronfield
Welcome.
I’d say that’s def oil cooler. It’s where mine was leaking. If left too long the oil gets in the coolant. Also the cooler could have warped so won’t be fixed by just doing seals.
Not sure on other bits….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #711774 13th Feb 2025 9:08pm
DrRob
That’s the worst I’ve seen for sure. Oil cooler looks to be the top culprit Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711781 13th Feb 2025 9:43pm
diabloam
I have order the two wee seal the BS611 ones, will start there as cheap, likely?
Any pointers on my other two issues, many thanks
Post #711791 14th Feb 2025 12:59am
pcourtney
Rear Propshaft Bearing - they don't last that long I am afraid - sorry Sad
I have just bought one of these JXB driveshaft carrier upgrades, pretty pricey though !
https://www.fullfatrr.com/forum/topic69739...re+bearing
UK Supplier - Darkside Developments
https://www.darksidedevelopments.co.uk/pro...-0-v8.html
other threads on the bearing
https://www.fullfatrr.com/forum/topic62227...+propshaft
https://www.fullfatrr.com/forum/topic58980...re+bearing
Post #711792 14th Feb 2025 1:43am
diabloam
So I have got the vitron seals for pipe, but is the recommendation to do the oil cooler at same time or just try oil pipe seals since can be done quicker, whats the general consensus. I was planning to do a full service anyway, so am I best just getting cooler and just doing it for peace of mind.
Checked oil level and it said underfilled so added a litre I had, then gauge was saying add 1.5 litre which I did not have to hand. Thought it would be ok, went for 20 mins spin. Then parked in same spot and left for ten minutes. At first said unavailable if I recall correctly so did the bonnet open and cruise cancel button twice trick and it said oil Ok and showing one mark below full. Can someone tell me where my oil is actually at. Hate these dash gauges, what the hell was wrong with a dipstick, same with EPB! lol
Found setting in dash for TPMS to be set to heavy or something but it still moaning to check spare tyre pressure. sensor knackered on spare?
Still got the clonk when turning right at slow speed, sure can feel it through left arm on centre console but is there conclusive way to test the bearing, read the suggested threads but they seem to have a drone, mine does not drone, just a light thumping on right hand turns at slow speeds.
Was looking to buy the GAP IID, its generally the older landies I work on so guessing I am best with G3 rather than G4 or am I better going for long term and getting the later version
Sorry for so much questions, just wanting to get up to speed on this wagon as tend to keep them for long time
Many thanks all
Post #711922 15th Feb 2025 8:13pm
mjdronfield
It’s def oil cooler. Amount of oil would not come out of the pipe seals, but good practice to do those whilst you are at it.
Oil will be in the V and running down back of engine.
If you take the cover off the engine I think you might be able to get a pic of the pipe seals with your phone or use endoscope to check what they are like.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #711925 15th Feb 2025 8:23pm
DrRob
Check oil when cold. Should be a couple of notches above mid way. Anymore and will show overfilled when not. Best way to check I’ve found Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711926 15th Feb 2025 8:25pm
DrRob
Do the oil cooler. New cooler and seals etc. Do the Viton ones at same time.
I bet there’s oil swilling in the V Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711927 15th Feb 2025 8:27pm
diabloam
Thanks, am thinking I would just be worrying about it, where is best to get it and do I need genuine one? I took pollen filler out at scuttle at had a nosey down back with mirror, there is defo oil around and on that pipe but think there was semi dry oil on cooler at front end opposite side from pipe and also same on top of cooler so guessing safe to assume between your experience and what I am seeing that best to change cooler, thanks
What brand oil cooler recommended. Also anywhere do good service kit of filters etc and I reckon I will get 20l Smith & Allan Momentum C1 F 5W-30 - Engine Oil, sure seen that recommended.
Probably do coolant whilst at it. I see the water pipe elbow that goes into cooler can be problematic, does it always leak after being disturbed or usually ok, just wondering if I should get it or usually ok
Thanks
Post #711928 15th Feb 2025 8:28pm
DrRob
Nissens is fine from site sponsor Advanced Factors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #711929 15th Feb 2025 8:30pm
diabloam
will go for that
https://www.advancedfactors.co.uk/lr022895...0-988142-p
ordered oil, just got the 20l
assume there no oil filter in it but can get service pack
Post #711930 15th Feb 2025 8:55pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
When changing the oil cooler assy, as well as the 2 rear pipe oil seals you should also change the water feed O ring on the right side of the cooler as you face the car, it's a push fit right angle connector and the original O ring will be squared and hard when you remove that plug and will just leak coolant if you don't change it.
18mm x 2.5mm https://www.ebay.co.uk/itm/141455807142?var=441967645571
I didn't change the lower gaskets on my cooler even though I did buy new ones. The Nissen unit came with one already fitted, some say do the lower plate ones as well but I had no leaking there, but I didn't bother and no leaks now.
I think all told about 3 hours and there are some very good guides on this site. Don't tip the cooler when you remove it or you'll have oil everywhere, the unit doesn't empty itself, lift and drop into a bucket.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #711933 15th Feb 2025 9:37pm
