![]() | Home > Technical (L322) > New 2012 Westminster owner, 3 months in after some advice |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, depends on what you buy, the Nissen unit I bought came with the rubber gasket already fitted so no need to buy an additional one.
diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 25 ![]() ![]() ![]() |
cheers very much for the advice, qq, do I need to drain the oil or coolant or just a bit comes out I am seeing. I have bought the draper oil extraction tool but it has not come yet, however cooler and seals are here so can I do this without draining anything as might get fired into this tonight and tomorrow. I notice the new cooler has new oil filter assembly on, assume there a filter in it (should I check I wonder), and I have spare filter to change oil after so ideal to change cooler, get it running, check for leaks and do oil change after. Also similar with coolant, leave it filled, take a bit of spillage and change that again? many thanks |
Hi,
Got start on this earlier, about point to release water pipes and unbolt cooler, not been to bad to this point, tip to cut short these little studs helpful, I found by cutting one plate comes off ok. Noticed got some not terrible oil stain round throttle body and air inlet pipe, inside intake pipe was just the normal light smear of oil you get through intercooler so don't think its from there. Could this also be from cooler but getting sprayed forward on occasion or suggestion where common leak. Pic is from drivers cylinder bank but actually bit more on passenger bank, not really soaked looks partially dried up which made me wonder if it just a little from cooler also. Will post progress if get back to it tomorrow. Have also removed the battery (bit of a faff also) to charge it since car sitting. Will stick pics up tomorrow to help anybody else doing this, hopefully go smooth, thanks
Well, got it off short while ago, but disaster as I was removing it I leaned on what looks like top bit of thermostat housing or something and broke off small bore pipe at top as in picture. Its the other end of the pipe thats prone to snapping off as you take inlet pipe to throttle body pipe off. It looks like the top bit unbolts what is it and can it be bought separately or am I looking at whole thing
think it called bleed pipe, LR023142, assuming I am probably the only idiot who has managed to snap this off before. But if anybody has taken that off before does it just unclip on wee tangs on either side? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1301 ![]() ![]() ![]() |
Just done mine. I think it is LR022690. £54. Comes with the two outside hoses and sensor.
I didn't have a lot of coolant come out when I did mine, probably because I used my electric oil pump to drain out as much as I could from the header tank so the level was probably below that of the cooler.
yeah AndyRoo, I always seem to create new jobs whilst working on them, lot of plastic these days. Bleed nipples in calipers can be nightmare, I have one of these induction coil heater tools, cant recommend it highly enough for them. I have a old 944 turbo with Brembo calipers, 2 nipples in each alloy caliper and most snapped, working way up drill sizes works, suggest you try that, they usually release way before you are hitting the metal of the caliper body, nipples only threaded 2/3rd length so can go shallow, patience, got loads out like that, certainly worth a try with some good bits before scrapping caliper, assume its the big 6 pots on yours?
Forgot to say Kevinp, anything I need to watch out whilst changing that housing or did yours come off ok, etc? thanks again all, really appreciated, great forum and I will try contribute when I can, great help |
I was doing the oil cooler first and honestly my hand just brushed past that hose and it broke.
well went to fit cooler and was checking new one and noticed this pipe has been slightly flattened
I think that may have been dropped, just looked at images on google and of the fifty or so I saw all are perfectly round.
yeah, will give AF shout tomorrow, hopefully can get replacement thrown in with order for that housing. Whilst on subject of coolant, the 90 degree elbow, cause I am leaning way over car was trying to make out the o ring inside it but cannot see for sure. Before I go poking about with pick am I right in picture below of where o ring is marked with green line?
