Home > Technical (L322) > 2010 4.4 TDV8 - P2264-00 (2F) Water in fuel sensor circuit
Page 4 of 4 <1234
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
We became friends with my amber triangle, as long as there is no other underlying problem for it to appear I am ok. It just comes and says hello here and there because of the water in fuel none sense of a sensor Smile Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #711914 15th Feb 2025 7:43pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hello All,
After being in the Arctic in winter I had one or two water in fuel warnings.
During fueling while it snows I've seen some snow flakes fall into the fuel opening and after driving on snowy roads there's always snow packed behind the fuel cap so I was accepting the warning.
They also disappeared on their own after an ignition cycle.
Recently, almost commuting between Mainz and Amsterdam every weekend, I've had the warning too, 3 times, WITH the Restricted Performance triangle.
Usually right after a cold start.
The car doesn't actually seem restricted, not like a RP that's turbo change-over valve related (had that too after being parked in -15C for days, also disappeared by itself after a warmed up car and an ignition cycle)
Using a fair amount of fuel the last couple of weeks I could not 'accept' there was actually water in the fuel.
As far as I read the WIF sensor detects a change in resistance between diesel (high resistance) and water (low resistance)
To me, a proper ground of the housing would make the resistance to ground (if i measures that way) lower, and that's not good.
The comments about using vaseline on the contacts triggered a memory seeing 'grease' on electrical connectors before, in other cars.
Some googling gave me Dielectric Grease.
As that's silicone based it may be a better option than vaseline (oil based) when it comes to longevity.
So that's what I'm going to try soon, it makes sense.
A 'short' between contacts lowers resistance making the ECU think "Water!"
I will report back Smile 2012 4.4TDV8
2000 Honda S2000
Post #715167 30th Mar 2025 9:00am
SpitfireS
Last Sunday, after a 470km drive, it popped up again!
Parked the car, put luggage inside, started the car to put it in the proper parking spot: RP warning that turned out to be P2264...
Monday off work, no driving.
This morning I cleared the code, no code during afternoon commute.
This evening I put some silicone (dielectric) grease on/in the plug.
Days without WIF error: 1 2012 4.4TDV8
2000 Honda S2000
Post #715366 1st Apr 2025 8:00pm
Page 4 of 4 <1234
