Home > Technical (L322) > 2010 4.4 TDV8 - P2264-00 (2F) Water in fuel sensor circuit
Page 3 of 4 <1234>
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
It seems like the cable loom from the part I bought from ebay(see above) fixed my issue. Its half the price of the part from maltings. In addition you get a genuine fuel filter and housing. Im not sure if they would fit to L322. This summer I will compare the fuel filter to the one I have on the car now.
If anyone knows, let me know 😉 2011 Vogue SE 4.4 TDV8
Post #687711 10th Mar 2024 6:11pm
pcourtney
garyRR wrote:
It's quite common for the contact inside the rubber plug to break over time and cause the water in fuel sensor fault code.
The cable on its own isn't available anymore, and the assembly for a 4.4 TDV8 is £300+. However, the loom from the 3.6 TDV8 fits and an entire assembly can be had on ebay for <£30, which you can remove the loom from and add to your car.
GAP IID is coming up with "Water in fuel sensor fault code" , I clear the code but it comes back 2 or 3 days later, this contact inside the rubber plug breaking down over time makes sense, mine looks OK but I replaced it anyway, sadly it did not solve the fault popping up later on in the day Sad
Post #687717 10th Mar 2024 7:52pm
EVOeng
For those that are struggling to find the genuine LR sensor harness which is no longer available separately to the fuel filter assembly - it is a Ford part. The part numbers are 6C119155BE
and 1685716 and can be bought for £40 on eBay.
Post #688043 13th Mar 2024 11:33pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
been getting this on and off for a couple of weeks and had been hunting all over for the replacement parts, much appreciated the heads up on it being a Ford part! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #688059 14th Mar 2024 11:04am
SoT RR
Sweden 2011 Range Rover Vogue 4.4 V8 Java Black
24valve wrote:
yep - still no issue from me....well, not on the water sensor front anyway!
Hi,
I been having the same problem as you had with the "water in fuel sensor" and the RP varning. Did the problem reappere for you or did the change of the harnes and sensor cure it long term?
BR
//Ted
Post #693627 30th May 2024 2:27pm
Mfcetin
Replacing the harness worked for me. Done more than 3000km and not a single time came that RP warning. I replaced it with a new one from a fuel housing assy for a RR sport 2011 Vogue SE 4.4 TDV8
Post #693634 30th May 2024 3:19pm
pcourtney
some have also had success with a smear of vaseline ( petroleum jelly ) applied to the connector circled in yellow
https://www.fullfatrr.com/forum/topic70911...t=vaseline
Post #698286 18th Aug 2024 10:37am
SoT RR
That's worth trying, thanks!
Post #698458 20th Aug 2024 2:25pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Thanks for the tip. I smeared Lanoguard grease on the connector two weeks ago, and no error code since. Coincidence? Time will tell. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #699034 29th Aug 2024 8:08am
pcourtney
Excellent news RR2B Smile
That's 4 or 5 of us now that have used that tip to solve the Water in Fuel error code that keeps popping up and showing "Restricted Performance" on the dash display.
Post #699064 29th Aug 2024 2:45pm
RR2B
[quote="RR2B"]
Over 4 months on and no further error codes. Success! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #708477 6th Jan 2025 7:21pm
pcourtney
fab news - well done that man Smile
NB you will need to dab a bit more on, mine only lasted 6 months, I asked my Dad if he used anything on his boat, that was waterproof grease type of products, and he gave me a little bit of Aquaslip, so far so good Smile
Carlube Aquaslip Marine Waterproof Grease - its not cheap to buy sadly, but he had some left over for me to use, otherwise I would not have used it.
Petroleum Jelly ( Vaseline ) will only last so long I reckon, your mileage may vary !
Post #708481 6th Jan 2025 7:40pm
GGDR
Hi guys
so I have been getting this intermittently.
With MOT day I thought crap it might fail if it throws the error
So I unplugged it.
Immediately the dash warning did not go off
So I thought ok it's a NC or NO circuit and unplugging should hide the error for MOT.
But
then it came on 10 mins later.
So what is it a broken wire along the line?
Is that why ppl replace the harness?..
. Cheers, Greg
Post #710483 28th Jan 2025 11:48pm
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
I still have this problem too, kind of learnt to live with it. It comes and goes at it pleases. It never goes off she it comes and car is on until it is off and parked for a while then it is just pure luck if it comes again or not. Never comes on while driving only when I start the car. Definitely water in fuel and definitely something to the with fuel priming with that damn sensor being broken or something. Lots of Vaseline or little bit Vaseline has been used in and around the sensor. Helps but still comes back annoyingly. Housing needs to be changed I think, but I will leave that to another fix I will combine with to do later. Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #710559 29th Jan 2025 8:23pm
pcourtney
fatu - yes the harness will need replacing eventually, it is a known problem, a friend of mine just bought the Ford Transit Part Number 1685716 FORD TRANSIT (2006-2013) MK7 2.2 2.4 3.2 DIESEL
He only paid £30 for it on ebay, we removed the harness ( as shown in the photo below ) from the new Ford Transit part, we carefully removed the old harness and the thin wire that plugs into the bottom of the fuel filter, then we used a 13mm spanner to move the fuel filter bracket off the bolts to get better access, you do not need to disconnect any pipes or hoses to do this, then using a small blade screwdriver took off the old harness cable and replaced it with the new harness, and pushed the thin wire back into the bottom of the fuel filter, job done, it took us only 15 minutes, any DIY person can do this my friend Smile
the Ford Transit Part 1685716 easily found on ebay
Post #711724 13th Feb 2025 12:56pm
Page 3 of 4 <1234>
