![]() | Home > Technical (L322) > 2010 4.4 TDV8 - P2264-00 (2F) Water in fuel sensor circuit |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Not exactly the same as your issue but close, When I got my 3.6 the seller advised of random fuel in water messages, he had taken it to the dealers who diagnose the filter housing assembly was faulty, they fitted a new filter only as the housing was $$$$. After getting a few Eronius messages I just remove the main plug to the housing, not the wire to the sensor no more warnings. 2007 TDV8 VSE
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
thanks for the reply
OK so I've unfortunately (as it seems) wasted the afternoon chasing the wiring. The wiring diagram in the Wiki seems to be outdated/incorrect. See image attached - the brown/black wire coming out of the WIF sensor to pin 10 on the ECM doesn't exist. The junction SJ934 only connects pin 10 to both glow plug module controls, and doesn't tee off to the WIF sensor. The WIF sensor earths directly to the chassis with a black wire.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
Thanks Jimmie, can you share the link to that workshop manual/document so I can look at the other wiring diagrams?
go topix. Pay few $ for 24 hours access and get everything you want specified for your car. |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
Interesting, because I've got exactly the same problem on mine - same symptons to the letter as the OP.
Selfishly, glad it's not just me.
The part I ordered was just the wires, so the bit that plugs into the bottom and the bit into the top - not the whole assy/housing.
I have seen some posts mentioning replacing the housing fixing issues - the housing looks to be 'earthed' via the small 7mm? bolt that attaches the wiring to the housing - I assume it measures the resistance across the fuel from the sensor, to this 'earth' point.
okaaaayy....bit of an update.
Glad to hear it mate,
I'm intrigued to hear your fix.
still all good Neil?
