![]() | Home > Technical (L322) > L322 Suspension Calibration |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35479 ![]() ![]() |
thats impressive nino.. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Well done Nino Nino that looks just like the official LR tool |
RG2024 Member Since: 08 Oct 2024 Location: Warwickshire Posts: 39 ![]() ![]() ![]() |
Just gone to calibrate mine with the IID tool. Started front left, on the screen where I press the arrow up or down until centre of wheel is 493mm from wheel arch. I pressed the upward arrow as it was a fair way off. It lifted, there was a knocking noise & it came back down to where it was pretty suddenly. I looked inside the arch, airbag still inflated. Couldn’t see anything obviously amiss.
Cr8r78 Member Since: 25 Nov 2024 Location: Texas Posts: 8 ![]() ![]() ![]() |
If you have lift rods installed is there a way to calibrate the suspension?
I got to the first stage of recalibration on the programme. So the procedure is to measure centre of wheel from wheel arch, and press the up or down button in the app until the measurement is 493mm. The app takes you through it step by step.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 186 ![]() ![]() ![]() |
Maybe a silly thing but did you drive the vehicle at all, it might be just a case of moving it about for a bit and getting all new components to settle.
No I've not driven it yet. It was an MOT fail when I got it so this is me doing the final bits to get it ready. I plan to take it for a short test drive but I haven't got headlights fitted yet, waiting on replacements (I tried to restore the original lenses and made them worse!). May just run it up and down my drive this evening.
