Home > Technical (L405) > headlight buls
dave the builder
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
headlight buls
Can i please opinions on which bulb change to, im after brightness and a long beam, i live in the country.
any advice much appreciated
osram nightbreakers unlimited
osram cool blue advanced
osram nightbreakers laser, are these worth the extra £ ?
Philips xtreme vision gen 2 .
Post #710604 30th Jan 2025 4:44pm
mjdronfield
Folks are fitting LED bulbs with good results.
A few threads already on here.
https://www.fullfatrr.com/forum/topic53573.html?highlight=bulb
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #710607 30th Jan 2025 5:39pm
dave the builder
Hi thanks, I've heard bad reports about leds so would rather stay away.
Post #710611 30th Jan 2025 6:23pm
mjdronfield
Think that’s in standard headlight units. The L405 has projector units so they aren’t a problem. Up to you obviously.
There is talk of the HID upgrades in that thread too which you will probably prefer then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #710612 30th Jan 2025 6:29pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I fitted mine my15 non adaptive headlights with xenarc philips and after repaced with led. Leds are working much much brighter.
Post #711278 6th Feb 2025 9:42pm
Waylander11
And there in lies the problem yes leds are much brighter unfortunately they are too bright it’s mental how bright some of them are and when driving at night and oncoming traffic is so blinding it’s a struggle to see the road
Post #711280 6th Feb 2025 10:07pm
Gremlin500
This problem is so poorly understood:
Idiots are fitting these LEDs into reflector headlights (designed for Halogen bulbs) -where the original bulbs had a cut-off plate inside the bulb. The LEDs don’t have this, so its like driving on main beam all the time, blinding oncoming road users.
The FFRR has projector headlights, with a physical cut off blind inside the headlight assembly, rather than inside the bulb. This gives a clean cut-off line on dipped beam, above which the light simply does not shine. The original yellow halogen bulbs on the L405 produce very poor output, even compared to the L322, which previous L322 owners have often complained about.
One caveat is of course on wet roads, where brighter lights will cause more glare off the road surface.
The L405 is also self load-levelling, keeping the headlights in trim, so not one of the worst-offending vehicles out there, unlike my Ford Ranger which comes with blinding headlamps as standard Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #711285 6th Feb 2025 10:59pm
sgorianin@gmail.com
Im completely agree with you on all points, as owner of l322 and l405 after led fitted in on both i stopped looking further to upgade headunits.
If light patern set as it should it returned back with amazing outcome.
But also heard different opinions specially from the persons who had glasses and using them constantly that while driving for more then 2 hours they start tearing…. I think its personal but must try before any conclusions
Post #711294 7th Feb 2025 6:13am
