Home > General (L405) > Windscreen woes
garyRR
My windscreen has now been fitted. Credit to both Aviva and AutoGlass, the whole experience was completely hassle free, and no questions were asked when I requested a genuine Range Rover screen.
I see Range Rover have updated the design of the windscreen which I rather like! The bezels are smaller and squarer, the screen is also flatter like the latest Range Rovers, and the heating elements are barely noticeable.
Everything is working as it should and there is no wind noise.
 2015 Range Rover Autobiography 4.4 SDV8
Post #701712 7th Oct 2024 4:37pm
Nabbler
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I never knew you could request a genuine screen but obviously that’s the way forward if I ever need a replacement. I’m with Aviva myself do you mind me asking what excess you had to pay for the genuine screen?
Just of topic a little I see on my policy that sunroofs are not covered but can be claimed if full excess is paid mine I think is £700 does yours mirror mine ? 2021 SVautobiography Dynamic Black ( Black wheels need to go )
1997 C140 Mercedes Benz CL500
Post #701713 7th Oct 2024 4:47pm
garyRR
The excess was no extra for a genuine screen - all I had to do was request genuine from AutoGlass, they raised the request with Aviva for approval and then scheduled me in once Aviva sent the approval.
Regarding sunroofs, I'm unsure. I'm assuming there is an increased excess for panoramic roofs. 2015 Range Rover Autobiography 4.4 SDV8
Post #701714 7th Oct 2024 4:51pm
Rob99
A number of insurers will not agree to a branded Range Rover genuine screen, Direct Line group (inc Churchill) being one. I argued with Churchill for 2 weeks about a genuine screen but ran out of time to pursue further as had to get it MOT'd. The replacement is fine and was fitted properly at an AG service centre as they had to calibrate and check the ADAC sensors etc. but I do feel aggrieved that I pay a high premium, presumably as RR repairs are more expensive than a bloody citroen C1, and then don't get genuine parts.
On the sunroof issue, when recently renewing my insurance there were quite a lot of policies which do not cover sunroof glass and with a sliding pano roof on mine which, by all accounts, costs £000's to replace I wanted to make sure it was covered. It's always necessary these days to look at the fine print and also sometimes to contact them direct to get clarification. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #701717 7th Oct 2024 5:09pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
That looks like they did a top job and with a genuine screen you must be happy.
I am kicking myself for not calling Aviva and asking to have AG fit a genuine screen after the initial attempt by National Windscreens with the XYG screen.
Although my screen was fitted correctly on the third attempt the XYG screens feel thin and cheap compared to genuine. The markings show it is only 4.8mm glass but I think genuine is 6mm.
Post #701733 7th Oct 2024 7:52pm
Glackowitz
United States
What’s up with windshield replacements on range rovers?? About 2 months ago we took a rock on the freeway and a nice big double bullseye right in driver view. Luckily our daughter is our insurance agent and was already setting up a claim to our insurance. Talked with glass shop and it took them close to a month to find an oem windshield (oem for l322). Window finally came in and was installed that night on a drive out to our other daughters home we had a hum and a buzz at 55mph and above, took car back to shop and they said they couldn’t reproduce sound and gave it back. I spent about 5 minutes at home with some blue tape and resolved the noise, car went back for 3rd visit and they spent another hour or so looking at it with every excuse for the noise except the install of the glass, again given back unresolved. Did some research and found as I mentioned to them the cowl getting disturbed will cause this and should be lightly glued to windshield to fix, took back again and they said sound wasn’t able to be replicated, so wife got a ride to shop, took the shop owner and a tech for a ride on freeway and sound was there, again they tried to say it was the wipers, the a pillar cover, a missing piece of weatherstripping from under hood, everything but the cowl they removed. I called and they said they would try a few things. They put some of the black putty on a couple spots under the cowl but not fixed. Called again and asked specifically to have cowl glued to glass and was told again not not policy to do that due to getting it loose later if glass needed to be replaced again, anyway long story long, finally after 6 trips to the shop it was glued down and no more tape on cowl and hum and buzz gone. Will not recommend that shop to anyone, but was only one for insurance claim besides safelite and they were as bad on my work truck.
Post #702139 14th Oct 2024 5:44am
Alex1976
So the latest chapter in my windscreen saga……
In the recent cold weather I actually used my heated screen for the first time. The passenger side cleared fine, but the drivers side remained misted.
I have checked the connections and nothing obvious in terms of loose connection etc. so suspected faulty screen.
So National Windscreens are coming out to fit my 4th new screen in the space of 5 months!
Post #709253 15th Jan 2025 8:22pm
Alex1976
So only ended up with the screen being looked at today and it turned out the drivers side had been incorrectly plugged in with the windscreen element being plugged into the wiper park heater. Connections swapped around and now all working as it should.
Post #711222 6th Feb 2025 12:40pm
Rob99
Result Thumbs Up
Bet you're pleased you didn't need another new screen Whistle
Begs the question why the plugs aren't different to avoid mistakes. 2021 D350 Fifty Edition - Carpathian Grey
Post #711224 6th Feb 2025 12:47pm
Alex1976
I wasn’t going to let them replace the screen today with this freezing fog as despite them saying their sealant/adhesive would be ok, everything I can find says it should be min 5*C and ideally around 20*C to ensure correct application. So really pleased it turned out to be a simple plug swap!
As you say - it’s really odd they are not different sizes to make it impossible to mix up.
Post #711225 6th Feb 2025 12:58pm
I think they are telling you porkies.....
You can't get the plugs mixed up, I suspect they just forgot to plug it in....!!! Rolling Eyes
 Pete
Post #711227 6th Feb 2025 1:32pm
Alex1976
Well that makes more sense that they are in fact different plugs!
Just glad it’s all sorted as I really didn’t want to go through the drama of a new screen as it took three attempts to fit one correctly before.
Post #711230 6th Feb 2025 1:57pm
exactly what my problem was...A pillars off and plugs changed.. ... - .- -.
Post #711235 6th Feb 2025 2:48pm
