![]() | Home > General (L405) > Windscreen woes |
Nabbler Member Since: 11 Jul 2024 Location: South West Wales Posts: 118 ![]() ![]() ![]() |
I never knew you could request a genuine screen but obviously that’s the way forward if I ever need a replacement. I’m with Aviva myself do you mind me asking what excess you had to pay for the genuine screen?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The excess was no extra for a genuine screen - all I had to do was request genuine from AutoGlass, they raised the request with Aviva for approval and then scheduled me in once Aviva sent the approval.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1454 ![]() ![]() |
A number of insurers will not agree to a branded Range Rover genuine screen, Direct Line group (inc Churchill) being one. I argued with Churchill for 2 weeks about a genuine screen but ran out of time to pursue further as had to get it MOT'd. The replacement is fine and was fitted properly at an AG service centre as they had to calibrate and check the ADAC sensors etc. but I do feel aggrieved that I pay a high premium, presumably as RR repairs are more expensive than a bloody citroen C1, and then don't get genuine parts. On the sunroof issue, when recently renewing my insurance there were quite a lot of policies which do not cover sunroof glass and with a sliding pano roof on mine which, by all accounts, costs £000's to replace I wanted to make sure it was covered. It's always necessary these days to look at the fine print and also sometimes to contact them direct to get clarification. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 146 ![]() ![]() ![]() |
That looks like they did a top job and with a genuine screen you must be happy.
Glackowitz Member Since: 06 Sep 2020 Location: Oregon Posts: 10 ![]() ![]() |
What’s up with windshield replacements on range rovers?? About 2 months ago we took a rock on the freeway and a nice big double bullseye right in driver view. Luckily our daughter is our insurance agent and was already setting up a claim to our insurance. Talked with glass shop and it took them close to a month to find an oem windshield (oem for l322). Window finally came in and was installed that night on a drive out to our other daughters home we had a hum and a buzz at 55mph and above, took car back to shop and they said they couldn’t reproduce sound and gave it back. I spent about 5 minutes at home with some blue tape and resolved the noise, car went back for 3rd visit and they spent another hour or so looking at it with every excuse for the noise except the install of the glass, again given back unresolved. Did some research and found as I mentioned to them the cowl getting disturbed will cause this and should be lightly glued to windshield to fix, took back again and they said sound wasn’t able to be replicated, so wife got a ride to shop, took the shop owner and a tech for a ride on freeway and sound was there, again they tried to say it was the wipers, the a pillar cover, a missing piece of weatherstripping from under hood, everything but the cowl they removed. I called and they said they would try a few things. They put some of the black putty on a couple spots under the cowl but not fixed. Called again and asked specifically to have cowl glued to glass and was told again not not policy to do that due to getting it loose later if glass needed to be replaced again, anyway long story long, finally after 6 trips to the shop it was glued down and no more tape on cowl and hum and buzz gone. Will not recommend that shop to anyone, but was only one for insurance claim besides safelite and they were as bad on my work truck. |
So the latest chapter in my windscreen saga……
So only ended up with the screen being looked at today and it turned out the drivers side had been incorrectly plugged in with the windscreen element being plugged into the wiper park heater. Connections swapped around and now all working as it should. |
Result |
I wasn’t going to let them replace the screen today with this freezing fog as despite them saying their sealant/adhesive would be ok, everything I can find says it should be min 5*C and ideally around 20*C to ensure correct application. So really pleased it turned out to be a simple plug swap!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8380 ![]() ![]() ![]() |
I think they are telling you porkies.....
Well that makes more sense that they are in fact different plugs!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
exactly what my problem was...A pillars off and plugs changed.. ... - .- -. Y. O. L. O. . |
