Home > Technical (L322) > problem with a TD6 advice needed |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
Have you done a leak test ?
4th Feb 2025 10:25pm |
zxrjohn14 Member Since: 01 Feb 2025 Location: Spalding Posts: 19 |
leak off test done and less than 10ml per injector while cranking quite a few times with metering tubes fitted.
5th Feb 2025 8:45am |
double post |
5th Feb 2025 8:51am |
yes injectors... i work a lot on petrol engines and have go to words, i suppose. I'm old and the brain doesn't work like it used to. |
5th Feb 2025 8:55am |
Any codes being thrown up ? .
5th Feb 2025 9:47am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 475 |
Had a similar issue with my early (2002) 4.4 M62 V8 Petrol L322.
5th Feb 2025 11:53am |
None what so ever. even on a proper LR scanner |
5th Feb 2025 7:44pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
You don't mention you have changed the fuel filter, I take it you have...??
5th Feb 2025 8:12pm |
brand new filter. |
5th Feb 2025 8:15pm |
The ineria switch stops the fuel pumping and this one has a healthy flow of fuel |
5th Feb 2025 8:17pm |
I have to ask... what's the WIKI?? |
5th Feb 2025 8:18pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 |
Top of the screen same box as the two cars shown. Red print WIKI is a forum compendium of information. John
5th Feb 2025 8:30pm |
thank you |
5th Feb 2025 8:41pm |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 |
I had similar issue on my otherwise reliable 2004 TD6, just would not start. ran on ezy start, or wd40, 1st time starting. went back to basics. solved it.
6th Feb 2025 12:17am |
