![]() | Home > Technical (L322) > 2009 l322 running board removal/delete |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
do you mean the fixed side steps on both sides of the FF?? ... - .- -.
ThisIsMyUsername Member Since: 20 Jan 2025 Location: Kent Posts: 8 ![]() ![]() ![]() |
Nope just looking to 'delete' the system from the car so it doesn't exist anymore 58 plate L322 3.6tdv8
define 'running boards'
Yes the electronic deployable side steps, in the diagnostic tool they’re referred to as running boards 58 plate L322 3.6tdv8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
I think there are some fitting instructions on here somewhere, will give you an idea of what might be where… think they have their own ECU, that’s what I assume you need to delete from the car. 2011 Range Rover Vogue SE 4.4 TDV8
https://www.fullfatrr.com/gallery/albums/u...ment~2.pdf
Thank you mate, I will have a dig around when the weekend comes back around and see what I can find.
