Home > Technical (L322) > 2009 l322 running board removal/delete
ThisIsMyUsername
England 2009 Range Rover Vogue TDV8 Santorini Black
hi guys
previous owner removed the running boards for various reasons and now its one of the final fault codes i get on my rapidly reducing list
i have a gap tool as of today and had a plug in and poke around to see if there was a seemingly simple way of getting rid of the running board system from the car but couldnt find it anywhere
can someone advise of the steps to get rid of the fault? do i need to disconnect any ecu's/modules?
thanks!!!1 58 plate L322 3.6tdv8
England, Kent
Post #710951 3rd Feb 2025 6:16pm
do you mean the fixed side steps on both sides of the FF?? ... - .- -.
Post #710952 3rd Feb 2025 6:28pm
ThisIsMyUsername
Nope just looking to 'delete' the system from the car so it doesn't exist anymore 58 plate L322 3.6tdv8
England, Kent
Post #710953 3rd Feb 2025 6:30pm
define 'running boards'
were they deployable? ... - .- -.
Post #710975 3rd Feb 2025 10:18pm
ThisIsMyUsername
Yes the electronic deployable side steps, in the diagnostic tool they’re referred to as running boards 58 plate L322 3.6tdv8
England, Kent
Post #710977 3rd Feb 2025 10:20pm
mjdronfield
I think there are some fitting instructions on here somewhere, will give you an idea of what might be where… think they have their own ECU, that’s what I assume you need to delete from the car. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #710978 3rd Feb 2025 10:32pm
mjdronfield
https://www.fullfatrr.com/gallery/albums/u...ment~2.pdf
https://www.fullfatrr.com/forum/post417154.html#417154
Maybe it will sort itself if you remove the ECU? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #710981 3rd Feb 2025 10:38pm
ThisIsMyUsername
Thank you mate, I will have a dig around when the weekend comes back around and see what I can find.
Got to admit I’m eagerly anticipating the longer summer days with this car where I can carry on tinkering after work. 58 plate L322 3.6tdv8
England, Kent
Post #710987 3rd Feb 2025 11:20pm
