Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 |
So , there’s a couple of mentions in this thread about cleaning blocked nozzles etc .
29th Dec 2024 8:43pm |
Keith Moon Member Since: 27 Jul 2021 Location: Devon Posts: 6 |
Thanks to the OP for this fix. My twopenneth - hadn’t been able to use rear wash for years so replaced blocked non return valve first and noticed very tiny drip from plastic inlet housing. Stripped bottom half of motor assembly, examined workings (which are fine), therefore no need to remove spoiler or wiper arm this time. Replaced new seal, tested and leaked worse than before. Luckily I bought 2 seals so cut remainder of plastic lugs flat to base of inlet housing, squashed second seal in on top of first as far as possible then really tightened the new small retaining screws and now no leaks.
31st Jan 2025 12:53pm |
